MattK said:Bottom line; can you show me a superior Mag drop in upgrade for a 3-6 cell light? Regulated?
I will agree that it is the best regulated mag drop-in on the market today for 4-6 cells, not 3-6 cells.
MattK said:*rolls eyes*
In your opinion what's better for a 3 cell that is also regulated?
MattK said:Appreciated but let's say for purposes of this discussion that output is identical for the TLE-DB3 and the TLE6K2 - wouldn't you rather have regulation and consistent output?
ElektroLumens said:Why just one Cree XR-E? Why not 3?
How about a drop in for a 2D Maglite, three Cree XRE, Micropuck per LED, Cree optics? Would pull 1.5A. I have P3's XRE's, so let's just say 80 lumens per LED, for 240 lumens approximate. Using 12,000mAh D cells, should last perhaps 8 hours more or less. Basically, remove the reflector and bulb, insert Cree assembly into head, replace bezel (add UCL lens?), screw head on Mag. Done.
Does something like this sound interesting?
Wayne
SuperTorch said:Yea and the Cree XR-E should rock in a 2 D Cell light, which is what I want. Hope it doesn't take 6 months.
yaesumofo said:The problem with this is we do not know how well the Cree emitter will do with the Mag Reflector.
FIRE_FLY said:test
Bimmerboy said:[hijack]
Fire Fly - You have 7 posts over the last three days, all saying the same thing. What's up with that?
Find all posts by Fire Fly
[/hijack]
EngrPaul said:MattK said:*rolls eyes*
Your TLE-DB3 is still the best option for 3 cells !!
EngrPaul said:I modified my MaxStar5 to Cree XR-E P4 WH on my 4D Mag. This works fantastic with the HS reflector. Soldered it in place with ArcticSilver5 under the pad. Still doesn't throw far, but makes a spot. Now I have the 130+ lumens I was supposed to get with the stock MaxStar5, and it runs 30F cooler. And it can be backed off for full flood.
