Are the reflectors in these big spotlights ie Sunforce, Thor, Pro Favorite, etc., as flimsy, thin, and cheaply constructed as the Sunforce 10M CP spotlight?:thinking:
"Quality Reflector":crackup:
The Sunforce HID appears to be physically the same as the 10 million CP model, the word quality should not be used in the same sentence. The light might perform well, but this is in spite of it's quality.:shakehead
OTOH I was able to see and handle an older model yellow Sunforce on display and the materials didn't seem as cheap, go figure.:confused:
PS I have read all of those reviews, thanks.
They are by no means state of the art, or anything really earth shattering. I think they are vapor deposited Aluminum, onto an aluminum substrate... like 99% of the lights discussed on CPF. I find they are robust/durable enough to perform the task at hand. So if thats all you ask for, you will be satisfied.
I don't think the reflector is the weakest link with a typical $100 spotlight, The charging systems, ignition, SLA cell capacity and fuse protection are all areas to address before the reflector and optics. Most do not even have fuse protection... which boggles my mind. IMHO of course.
If you are a white wall artifact hunter, avoid this sub forum all together and stick with hand held flashlights.
It's not always obvious. A stock Maglite reflector is plastic ...If you were to pick up a Maglite flashlight and compare it to a plastic $2 flashlight, you could see there was a quality difference because of how obvious it would be.
There are also $2 flashlights with metal reflectors. My point was more along the line of comparing quality when it's so obvious even a kid could tell the difference.It's not always obvious. A stock Maglite reflector is plastic ...
... and has a very pronounced doughnut hole when set to anything but a tight spot beam. I like mags but the OEM reflector is not really what I would consider "quality".It's not always obvious. A stock Maglite reflector is plastic ...
