Dangerous Do It Yourself Tools
Marlite
YVR
We all think we are capable of doing "stuff" because
we took shop at school and know theory and application
with lessons like measure twice and cut once, while
building a jewel box for Mom's birthday present.
But we need to build a room in the basement with tub
and toilet and now the fun begins. Home Depot is our
mentor of course! Read on.
TOOLS EXPLAINED BY A DO-IT-YOUR-SELFER
DRILL PRESS: A tall upright machine useful for suddenly
snatching flat metal bar stock out of your hands so that
it smacks you in the chest and flings your beer across
the room, denting the freshly painted vertical stabilizer
which you had carefully set in the corner where nothing
could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws
them somewhere under the workbench at the speed
of light. Also removes fingerprints and hard-earned
calluses from fingers in about the time it takes you to
say, 'Oh s**t'
ELECTRIC HAND DRILL: Normally used for spinning pop
rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too
short.
PLIERS: Used to round off bolt heads. Sometimes used in
the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to
convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the
Ouija board principle. It transforms human energy into
a crooked, unpredictable motion, and the more you
attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Generally used after pliers to completely
round off bolt heads. If nothing else is available, they
can also be used to transfer intense welding heat to
the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting
various flammable objects in your shop on fire. Also handy
for igniting the grease inside the wheel hub when you want
to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used
to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to
the ground after you have installed your new brake shoes,
trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by
most shops to cut good aluminum sheet into smaller pieces
that more easily fit into the trash can after you cut on the
inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum
tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum
seals under lids or for opening old-style paper-and-tin oil
cans and splashing oil on your shirt; but can also be used,
as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans.
Sometimes used to convert common slotted screws into
non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding
that clip or bracket you needed to remove in order to
replace a 50-cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the
hammer nowadays is used as a kind of divining rod to
locate the most expensive parts next to the object we a
re trying to hit.
UTILITY KNIFE: Used to open and slice through the contents
of cardboard cartons delivered to your front door; works
particularly well on contents such as leather seats, vinyl
records, liquids in plastic bottles, collector magazines, refund
checks, and rubber or plastic parts. Especially useful for
slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across
the garage while yelling 'DAMMIT' at the top of your lungs. It
is also, most often, the next tool that you will need.
Author Unknown
Re: Do It Yourself Tools
:twothumbs
That is way too many funny.
I have used most of those tools in the manners described.
Dude, I have tears running down my cheeks. I haven't laughed that hard in a while. Thanks! :crackup:
[Quote Wallace L;] :twothumbs
I have used most of those tools in the manners described. [/quote]
Thanks guys it resonated with me too!
I find it really funny when I goof up and hope nobody ever finds out, especially she who says "you can do it, you're just too lazy to start!
She doesn't know I don't want to start start because I'm trembling about the carnage she is forcing me to do and how much I know Mike Holmes is going to charge me if he will rescue me early! Now that I've made an admission of ineptitude I find I'm really a funny guy.
are trying to hit.
My favorite ones. :thumbsup:
BTW does anyone know where the post was where the person sucessfully trimmed their glass lens to the correct circumference using their table saw, and posted a pic of the configuration while holding the finished lens in their fingers? Talk about the heebie-jeebies. :sweat:
I think I snorted soda out of my nose... Printed and hung up in my shop, co-workers loved it. We spend all day building, maintaining and repairing a fleet of police cars, as well as some other town vehicles, so a lot of that hit real close to home. :twothumbs
First comment made when you realize that, becasue of one of those tools, not all your body parts are the same as they used to be.
Ooops? (Said as a question)
EArlier today I was telling a friend about my first night aas a grocery clerk. About 10 minutes after being warned of how dangerous the razorblades in a box cutter was, he woman I was working with said.
Ooops.
Three inches long and about 3/4 inch deep. Almost no blood and no pain for teh first few minutes.
I've got scars to prove a few of these. Only one major ER trip though, for figuring "the angle grinder doesn't REALLY need the handle that broke off, does it?"
Talk about dangerous DIY tool, the edge of table saw could be used as grinder, this was before I had a
bench grinder & evidence that I was temporarily insane :crazy:
Are you freaking kidding me!!! I've been pushed out of perfectly good airplanes twice now but I wouldn't try that one for anything dude. :eek:
Very funny original post Marlite. The last one reminds me of a guy that I used to work with as an Mercedes apprentice and the dude would flip out when things wouldn't go his way or he'd bust a knuckle on something. He'd pitch heavy tools like big wrenches and screwdrivers out into the parking lot behind us. I thought the guy was going to kill someone someday!
Oh god, this is so true!
Pliers... they seem like such innocent tools... they also gave me my most unique looking scar. Didn't even utter the "ooops!" I just applied pressure for few minutes, hoping that would do the trick. Of course, I hadn't really looked closely at my wound yet and it ended up being a bit of a bleeder. Ooops! I'm definitely going to be more careful around these dastardly tools from now on. :ohgeez:
Thnks for posting, that was great! :crackup:
I know I've done all that except the oxy torch. :laughing:
I know planty more of you guys have done the same, just admit it, who are you kidding, no sense in try to hide it! ;)
