FASTCAR
Banned
Just got my new DEREELIGHTs.2 and 5 stage OP and Smooth
Shipping was 5 days.
Came in a nifty black box for those that care about boxes.
Came with extra buttons and O rings.
Fit and finish on mine is as good as I have ever seen..at any price.
Grip is fine, I can't see ever dropping it.It looks in person like a very well made serious light.Mine is light grey and flawless.
Has a ring near tailcap for LEOs that like that kind of grip.Clip is a wire type and seems quite strong.Clipped in a pocket the head faces down.
All 3 grips work great on this light.Cigar,psycho killer holding a knife just above shoulder and low grip..as if your are holding your package for #1 release.
Clickey is fine, standard "Normal" FWD style.Mine came with 3 rubber buttons.Black/thick,black/low profile,green / glow in the dark.
This light CAN tailstand if needed.
It is about 3/4 of an inch longer then a Wolf Eyes 6a.All of that extra 3/4 is a DEEP reflector.
Threads had no dirt or crud on them BUT came bone dry.After a fast wipe I used my secret "Dow Corning high vacuum grease" lube.
Threads are coarse and thick, MUCH better then all other china lights I have seen.Not quite Surefire threads..but close.
Glass was totally clean, It should be tough A/R glass.I have no way to know if it is.
Some lights feel goofey in the hand. This light feels just right.
Both of mine are Q2.The 2 stage works easy.Tight for high,- 1 turn or so for low.I find the 5 stage a bit odd.Might just be me..perhaps I am not use to it.Function is fine though.Low is quite low for the low lumeniods.Strobe is just fast enough to annoy:thumbsup:
BEAMS: Both very white
Smooth reflector: Typical very ugly ( white wall) ringy, and artifacts.Throw is fantastic.This reflector is DEEP and beam is small and tight.I think it out throws all other 2x 123 type lights I have owned.If you need a spot outside this is great!
OP:This is not the most agressive OP I have seen.I would say it is between Wolf Eyes OP and LOP.
Beam has less artifacts as expected.I would not call it floody..but it is a "better" beam for the white wall hunters.Out side in real world use the beam is fine.I would guess 15% less throw for 15% better beam.Center spot is a tad bigger.
I already installed my diffuser and its fantastic.
http://www.candlepowerforums.com/vb/showthread.php?t=169191
Is this light worth $60? YES
Is this light better then most at this cost : YES ( better then most costing double or tripple).
Would I buy a S*refire instead of this light: NO
Dereelight and Wolf Eyes are my 2 favorite brands these days.
Pickey little things:
I dont care about tail stand.I wish button was longer OR end of tailcap was not concave.It would be easier to turn on ( not that its hard now).
I just prefer a button that sticks out like a S*refire Z28 whatever cap a L4 has.
I have had this for 1 day.Unless some crazy issues happen or an explosion, I love this light.
I LOVE that the LED module screws into the reflector.When Q5 or better come out you can get a low cost upgrade that pops right in.
**This is the first light I have ever owned that had clean contacts out of the box. I hit it with DEOXIT and got zero black ( dirt) off.
On my Bang-For-The-Buck-O-Meter : 10 of 10
Having owned and tested 100+ lights...if I was given this light and was asked to guess the cost....I would guess..150-250$
I will keep this light.
This light is a homerun !
If you are on the fence, pull the trigger.
My 2 cents
HUGE :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsupereelight
My 2 cents
