Ilikeshinythings
I spent a better part of my shift at work reading about alternative sources of fuel, and I came across an Austin Texas company called EEStor who is reportedly developing "supercapacitor" technology that would create efficient electric power with amazing capabilities. I came across this blog where the topic was discussed a little bit and it looks very interesting. Has anybody on here heard anything about this? Everything seems to be very hush right now but if this actually does come out and become mainstream it could be huge. Check it out!
http://thefraserdomain.typepad.com/e..._ultracap.html
A typical Lithium Ion battery takes 3 hours to charge...which is a great step up from nickel cadnium, but still no where near the time it takes to pump gas into your engine (2-5 minutes max). The increases in mAh have also been very good from early rechargeables to LI batteries, but they are also nowhere near the capacity of a gasoline engine. The Tesla uses over 6000 single lithium ion cells wrapped up in a box. LI batteries, like most chemical current cells are known for catching fire...so 6000 of them sitting right behind you would not be good in an accident. They also produce a lot of heat as they are pumping out generally higher voltage. So, the advantage of this new technology is 10 fold on every dimension. Not only does it create more power, it holds more energy in a smaller, lighter package that does not create nearly as much heat, and it does so without utilizing chemicals that are horribly harmful to the environment (battery acid). I strongly believe this will revolutionize the world in which we live.
Standard: 32 KWh = 100 horsepower.
Supercapacitor: 54 KWh = 169 horsepower @ 400 pounds, so two 400 pound supercapacitors = 340+ horsepower with a completely LINEAR torque curve with 100% available at 1 RPM all the way to redline. I dunno how much the average car engine weighs, but it would not be hard to make a 2000 pound car with this kinda power.
Also, I'm very surprised I haven't found anything on CPF regarding this topic with so many prominent electrical engineers present. Please tell me what you think.
