Hemicrusher
- Joined
- Apr 4, 2021
- Messages
- 92
Question...Except the 20% off new customer discount, does Elzetta ever send discounts to existing customers? I am thinking of buying a Bravo, but the price is a bit steep.
I was hoping for a little better than the 10% Insider Discount. beyond the 20% that I got on my first order. I have two 15% discounts and one 20% to use later from Malkoff, and even got a 20% on my first purchase.Registered/Logged-In Users will now see an Insider discount on ALL PRODUCTS in their cart!!
Sign-up for our Newsletter, the Elzetta Insider, and receive a one-time 20% OFF your first order!!
(May not be combined with any other offer or coupon. / Must be logged in at time of purchase. Use Code: subscribe20)
So I bought an Alpha Gen 3 with the high low tailcap. Is anyone else experiencing like a buzzing noise from the head or the light flickering. Mine flickers on occasion and sometimes it goes from like the old 415 lumen setting to the 500. Very inconsistent. Lastly, mine does not step down to 415 lumens after 10sec. Very disappointed.
Check out my posts here on page 205. Sounds like you might be having a similar issue that I had.So I bought an Alpha Gen 3 with the high low tailcap. Is anyone else experiencing like a buzzing noise from the head or the light flickering. Mine flickers on occasion and sometimes it goes from like the old 415 lumen setting to the 500. Very inconsistent. Lastly, mine does not step down to 415 lumens after 10sec. Very disappointed.
So I only run CR123A batteries in this light and no rechargeables. Tried the battery junction that it came with and swapped it out with a fresh Surefire battery with the same issues....and disappointing to hear JPA. I can only offer sympathy, but I can certainly sympathize.
You may not be in the mood for questions, but when you are...
Are your problem symptoms while using a CR123A, or lithium ion 16340, or both - and if both, are they each the same with either type, and have you tried more than one of which ever type applies?
Knowing that may help those familiar with the light as they contemplate the issue(s).
It is just the two of you.Good stuff, so it's not just me then,
the speed clip just seems to work great with the alpha, there were many people that really didn't like it though, think if they carried with it for a while they would have seen the benefits of it's design.
Think many didn't like the look of it compared to most other clip designs so didn't give it a chance.
those rings are fugly!!!The HC head came today. Initial impressions……. It's big. The tint is great. Looks very similar to the alpha gen 3. The beam has rings. Saying that, I haven't had a chance to use it for real though. I don't think the rings will be noticeable in real world use.
At least there are two of us that like the speed clip then. 😆It is just the two of you.
Elzetta has the EXACT same problem as HDS - they designed a spectacular flashlight with a clip as a pure afterthought.
It is frankly EXACTLY why both clips completely suck and why I carry neither brand of flashlight on a daily basis. They all sit in their respective packaging in the back of my closet.
So I got my alpha back pretty fast. They told me that there was too much grease and suggested that I use isopropyl alcohol and using 400 grit scotch brite pad to clean the the ground surfaces of the body/ tailcap. Got it back and really much better.Let us know if you've had a chance to confer with Elzetta Support about this. That's likely the best course of action, and I'll be curious as to their response / comments. Thanx!
Really happy with their customer service!
kind of surprised by this...So I got my alpha back pretty fast. They told me that there was too much grease and suggested that I use isopropyl alcohol and using 400 grit scotch brite pad to clean the the ground surfaces of the body/ tailcap. Got it back and really much better.
