EX10 >> MC-E
massimocaya
hi friends, if possible replace original cree Q5 of Nitecore EX10 whit new MC-E ?
dimension will be ok, but driver and reflector ?
thanks, Massimo
orrible beam ? . . .but Q5 and MC-E are not the same dome ?
not throw but fllody ...i think !
for heat not problem, i use this torch few second...
Diffusion film or sandblasting the lens would make it a flood monster. Then if you resisted mod the driver for higher output along with using AW's new IMR cells.... Mmmm sounds fun 🙂
of course, you'd have to be careful not to overdischarge the unprotected IMR cells, but in a "20 seconds at a time" light that may not be a big concern.
You would want to modify the driver as Thujone said, because an MC-E wouldn't be significantly brighter at the low stock drive current.
I can use a Carclo optic specific for MC-E :thumbsup:
. . . but i not know about this driver mod :thinking:
