I used a lightmeter to test the EX10 with AW LiFePO4 batteries.
I did the test twice for confirmation, but the results were near identical.
Each cell was fully charged a few days ago.
The test didn't start until after 30 seconds of runtime.
The test was done on the highest output setting.
The first sign of any dimming from the meter was at 42 minutes for both.
The battery was then immediately removed and tested.
Voltage after test 1: 2.18v
Voltage after test 2: 2.29v
The small difference there is due to the fact that I took slightly longer to get the battery to the multimeter on test 2 so it had already bounced back a little.
AW's recommended low voltage for the cells is 2.0v
2 points to note:
1: On both tests, the output stayed rock steady for the whole test, except for the last 20 seconds or so, in which it actually crept up very, very slightly in small increments, before then taking a dive. I assume that is normal as the regulator tries to squeeze out the last drops of juice.
2: I'm no expert, but I would have to say that the EX10 is very well regulated as there was very little time on the "down curve". The output level stayed exactly the same, then there was no more than 20 seconds between full output and quite dim. I couldn't see how far that would go though as the point of the test was to check the LiFePO4 voltage as dimming started.
So, EX10 and AW LiFePO4 cells.
35 minutes seems to be a safe time on high, after that, change battery.
2 points to note:
