LEDninja
I do not think so.BrightGal said:When the RAW (from Orb Flashlights) first came out, it was a direct drive and ran on high only; this light must have as high or even a higher discharge rate than the L0D CE on high. Yet, I have never heard of a RAW owner having battery problems.
UnknownVT measured the current on high at 1110 mA.
If we look at Newbie's voltage vs. current of thr XR-E here
http://candlepowerforums.com/vb/showthread.php?t=138503
Voltage under load is 3.3V
If we substitute a Luxeon K2 for the XRE (blue line instead of red line) we see a current of only 200mA!!! at 3.3V.
Now K2 have a high Vf and the XRE low.
If I assume a LuxIII is half way between a K2 & XRE, at 3.3V I would get 650mA, within the spec..
Thus I think we can get away with DD a RAW or L0D but not the L0D CE. The Orb has the additional advantage of using smaller batteries with less oomph which would limit the voltage and current further.
I started a discussion on driving 1.5V lights with li-ons here:
http://candlepowerforums.com/vb/showthread.php?t=151662
