I came to the light...
- Joined
- Nov 4, 2007
- Messages
- 1,059
The real magic of modern LED lights is how bright they can be in a small package. Usually the best larger throwers use the same power supply as the compact lights.
The best light that fits your descriptions is the Dereelight DBS V2, or the first version if you really want that extra cm. However, you may be a lot happier with a compact light. Since they use the same power source, compacts are just as bright, but do not have as much throw, as there isn't room for a larger reflector. I highly recommend the Dereelight CL1H for that, which has an extremely useful clip, so you may not miss being able to hold it under your arm. The Regalight WT1 V2 is also a great choice - between DBS and CL1H in size, no clip, between them in throw. Known for its excellent build.
I took a long time to figure out exactly what all the battery types are... I'll summarize it for your purposes. CR123As, the non-rechargeable lithiums, have the highest capacity, but may become expensive to continually buy. RCR123As are rechargeable versions of the CR123As, but be careful: they have a higher voltage, so not all CR123A lights take them. They usually last about half as long, with a bit more brightness, flat output, and a sudden shutoff. 18650s have the most capacity of the similar-sized rechargeable combos, but due to the fact that they are twice as long, a 2xCR123 flashlight taking them will receive only half it's normal voltage. Flashlights tend to have poor regulation on these batteries. However, Dereelight's digital versions ("D") are built for 18650s, and have excellent regulation and runtime on them.
One last note: Wolf Eyes products are known to feel like Surefires, and have arguably better build quality, as well as being brighter. They aren't as bright as a CL1H, but are a big step up from a similar-sized Surefire. Unfortunately their website is very unorganized and incomplete - if you're interested, pm me and I can tell you a lot more about their products.
