Sgt. LED
Now you see, this thread is just awesome for all of us.
I look forward to the results on everything's testing! Good luck guys.
Yeah , im not worried about having it tested , just having it killed !
I should have some Diamond Dragons on the way , so having a true scale to work from would be a bonus , rather than guesstimating .
Killing R2's , last thing Im worried about , I ran this one for 5 minutes on high and the head got warm , but the body was still cool , the LED is nice and yellow . No hint of color change in the output color .
My Mini MC-E runs about o.75A to 0.9A on medium and 0.15A to 0.2A on Lo , nothing to fear there . Again , if they die [ CR123 ] , no big deal . + I dont run Hi as a rule , Med puts out plenty of light . + Its a small price to pay for first hand knowledge .
Id rather be a do'er !
I used to go through Bulbs in my maglites like they were candy ..
Always ran bulbs a little lower in voltage to get more output ..
2D bulbs in my 3D and 3D/4D bulbs in my 6D ... The 6D , well the 3D bulbs lasted just once , turn it of and on again and they were gone , the 4D bulbs lasted about 20 to 30 minutes .
These cree's , are just the bees knees .. 50-000 hours who needs that , IM a hardcore computer overclocker , pushing cree's is much cheaper
So what happened to the big boast in post 21:
Or post 24:
Now I see what happens when the rubber meets the road.
That said, I believe that bigchelis is incorrect when he said "PM me if you want real lumen readings and not paper math readings". You have made real readings, comparing before vs after in some sort of homemade lightbox (same as described in flashlightreviews.com?). They aren't lumens readings, but on a relative basis, they should be reliable.
What is poorly documented is your experimental procedure, which IMO is the proverbial fly in the oinment. Plus, your continued reference to your PWM controller as a boost-buck gives me pause that you really know what you are doing. Your statement at the time that voltage doesn't matter, only amps when using your so-called boost-buck driver also indicates a level of inexperience. Voltage does matter since a DC-DC converter needs to generate the power required to be delivered to the LED. If you have a constant current driver rated, for example, at 1000mA forward current, feeding an LED with Vf of 3.5V requires that the driver generate 3.5W of power. If the Vbatt is 3.5V, and driver efficiency is 100% (for simplicity), then Ibatt=1A. If Vbatt=1.75V, then Ibatt=2A (assuming that the "boost-buck driver" can operate in regulation at these levels). But the forward current to the LED remains the same.
Voltage did not matter in the CR123A test ... It was not the important part of the test ,
killing Cree's , you must understand , if I kill one its ok , if some one else kills it ??? Not the same thing !
Im sorry , but your mixing stuff up , and I dont want to be rude about it ...
My L2 R2 Mini with buck boost driver = ProductId=5313 @ KD
Had nothing to do with CR123A test , or anything else for that matter . So I cant understand why your going on about it ?
It seems to me your mixing stuff up and then trying to shove it down my throat , so why dont you go bother some one else .
Matt
The driver is linked : Its a SSC MC-E driver / controller from KD , Im not confused about what driver Im using , ProductId=1845
My L2 R2 Mini has a buck boost driver installed , I was just talking about it in passing ... Also from KD - Do you need a link ?
