With those high numbers on an R2 you are likely gettting 150 Lumens. Seriously; From helping MrGman test several R2's, K2's, and Diamond Dragons. The high current(1A plus) in a P60 hosts just doesn't work. You could easily get 1.4A at the tail w/R2 in a 6P, but you will not get close to 200 lumens.
FYI: The only lights that got 200 plus lumens using an R2 were the ones set a 1A.
1. The Tiablo A10 R2 = 245 Lumens
2. The 1D Mag R2 at 1A =180 Lumens
3. The Dereelight 1.2A R2 = 200 Lumens
4. The Dereelight 1A R2 = 220 lumens.
For some reason the R2's we tested with over 1A of current suffered in the Lumens department. I wish more current meant more lumens, but so far it doesn't.
If you want to prove me wrong. PM me and you can send me that P60 drop-in and we can test it in a 6P w/UCL lens and IMR 18650 cells.:thumbsup:
FYI: The Deft "The longest thrower in the world" MrGman got 200 lumens out of it!!!!!!!!!
Thanks,
Jose
Well , its only my highest output R2 I own .. It exceeds all my Stock R2's , as for 1A , I have a R2 hooked up to a 1A buck boost driver and in my light box its doing 12000Lux , VS 16000+ Lux for this one .
I have another R2 drop in ordered + more drivers/controllers + some Diamond Dragons .... + It depends on the battery used .. Not all my 18650 can do 1.8A at the tail , only the non protected blue generics I got with my L2's can deliver such current .
Still , sounds interesting , I have another that can do 15000Lux with the same driver / batt combo , hmmm , :thinking:
PS/ Its only $15 USD to build your own , the postage would add up to that shipping it there n back ..
As for proof , I got a 30% gain in light output , from changing drivers , so thats my claim ! and my proof .
As for actual output ? I dont know , what can a R2 do when fed 1.6A ? Answere = 30% more .
I have changed drivers on two R2 pills so far , and both have increased output , I dont know what more to say .
I will do a 3rd as soon as the pill and drivers arrive , and then I will do some Diamond Dragons with the same driver/controller , and the DD are rated for 2A , so be interesting to see if they can do 2A or not .. and the DD are rated very high @ 2A .
