PSM,
The 2200 mA through the LED are certainly producing a good amount of heat, you will see the thermal output reduction if you leave it running for a little longer than that.
Really glad that you are enjoying your AquaRam, i love to hear about your experiences
Matt,
There are default values for the brightness levels that are associated with the number of output levels that you configure with setting #2. You'll find those defaults on page 8 of the user manual. They are listed under the setting #11 because with this setting you can tell the driver not to load the defaults when you change the number of output levels.
With just changing setting #2 (number of output levels) to 5 as you have, you now have 5 well spaced output levels (brightness levels 2, 8, 14, 18, 21) where the highest output level is still 1400 mA.
If you change the maximum output current (setting #16) to 2200 mA now, you will end up with actual currents for output levels 1 to 4 that are slightly lower than the stock drive levels 1 to 4.
If you want to have output currents similar to the ones on the stock levels you can refer to the table in post #67. If you compare the currents for the maximum output current of 1400 mA to those for 2200 mA you find that you have to use the brightness levels 2, 9, 15, 19, 21. Thus you'd have to increase output levels 2 to 4 by one each.
I'm glad you have been successful closing the jumper with solder, in fact thats probably the easiest method for all of you that have a smaller soldering iron (or if you use some trick as PSM has done
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Its too bad that you also had trouble with the silver ink pen. While i don't have a circuit writer pen but only some similar conductive ink in a small vial, i think that the problem is that when you first use the pen you always have a blob of ink with little silver in the tip, no matter how much you shake. If you first use the pen on some paper until you get a even silver colored trace and then just dab a thin layer of that well mixed paint on the solder jumper, it probably will work.
Hopefully you will find the right configuration for yourself, i really appreciate the great feedback!
And thank you Calflash, you have put things just right, i just wanted to elaborate a little
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
