kelmo
I just gave my rock climbing buddy my "spare" DS. He will appreciate it.
from the Nichia spec sheet, the new DS has a lower Vf (3.2-3.5) compared to the CS(3.6-4.0) so i'm assuming runtime should be better than the current Arc-P.
A little bit of wobble is normal. The LEDs have slope to the package and a diameter variation from unit to unit that causes them to be a bit tricky to center. We test each unit when it is being assembled with a special custom made roll test fixture (complete will ball-bearing flashlight holder and scaled target). We also have some tools for adjusting the beam slightly before the unit is glued.
Our specification (posted on our website) is that no unit should have a deviation of the overall center hot spot by more than 1/2" when shown at a target 6 inches away and rotated 1 revolution.
peter
I had not seen this answered yet, so I'll comment.
If the driver was current regulated, the lower Vf could result in a longer run-time. However, the driver is not configured as a current source - it is voltage boost circuit. In this case, the drive current may be a little higher which could result in slightly shorter run-times, but at a higher brightness. You would have to run a decent sized sampling to see if the lower Vf of the DS LEDs make a significant difference (probably not a lot).
Perhaps Peter has done some tests he would like to share.
Paul
EDIT: Just compared the data sheets. The binning letters are the same for the CS and DS except the DS goes to W (31-44cd). The V (22-31cd) and U (15-22cd) bins have the same ranges. The V-I slopes have changed indicating Nichia has changed their die brew which has resulted in the lower Vfs. I wonder if they changed phosphor and if the phosphor on the DS's are as robust as the CS's.
The driver is actually partially current regulating not voltage regulating.
I haven't got around to setting up a series of run time tests yet. I am sorry. A proper tests involves multiple units over a period of about a week. I also have 3 types to test (uv, snow, ds). To get a quicker idea, I tested the current consumption of the average DS head and compared it to the current consumption of the average CS. The DS drew slightly less current on average (the snows and UV appear even less). This tells me that, roughly, the runtime should be similiar if not slightly better. Rather than tell you guys it is better, I am only claiming it is similiar for now.
peter
Per measurements that I just did with a NiMH cell (1.289V open circuit voltage):Peter, I was wondering if this sounds right. My limited edition (marked on tail end bezel) pulls 170mA's from battery, and my new DS pulls 270mA's from battery. Light output of Limited Edition is about 1/7 of DS (bounce with lightmeter).
Bill
