Illum
same disassembly as http://www.candlepowerforums.com/vb/showthread.php?p=2011491#post2011491
thought I split my questions up for different forums.
this lamp was found to be housed inside a metal pipe and a high temperature rubber roller intended to feed paper between the heater and the toner cartridge.
not sure what I can do with it
heres a couple pics
Lamp and driver circuit, by the way it was built it wasnt intended to be taken apart, so I cut a few wires in the process of disassembly
theres this cute little gadget attached to the blue length of the wire, kinda hard to describe, about the width of a dime, about less than half an inch high, huge terminals with screw holes and when you shake it theres this slight rattle, cant figure out what it is other than the fact its not a ballast.
its not the thermal fuse either, which is mounted above the metal lamp enclosure reading "fuse 192 C"
any ideas?
the laser printer is a fax/scanner/printer/copier made by Brother, model MFC-6800
heres a couple pics
any ideas?
