smflorkey
This is looking like something in the 'must buy' category. Will, I think you're going to put a serious dent in my wallet.
Thanks man - I will be more patient next timeLOL, I've now deleted the duplicate posts. Sorry for the delay there, Will - I've been away for ~2 weeks.
Thank you. I am still travelling a lot for my day job, but I am still making progress towards the next prototypeThis is looking like something in the 'must buy' category. Will, I think you're going to put a serious dent in my wallet.
Thank you. The next prototype host will be closer to the actual size - I will not be using any Mag parts, so it will have a different look/feel.Wow! How did I miss this post! This is amazing and very cool control scheme.
The host that you made is very nice and I think you should make a light just like that with a flared tailcap and, of course your own bezel that mimics the head somewhat. Beautiful creation!
MagnetoDrive chiseled into the light would be an excellent name with some graphics like this ||||||||, except that the bars get thicker as they go to the right.
Steve,
I am using Hall Effect Sensors, but they are not enabled all of the time, so that helps keep current consumption to a min while in the OFF position where I also put the micro-controller to sleep.
I am not done, but so far it has been a fun project indeed. It is good to have a fellow EE here in the forums
Will
Yes, absolutely, just easier on the lathe. This fixture is just for comparing lenses (not to be used in the actual prototype), so this was quick/easy to do in the latheInteresting to see how you've done the LED post. Out of curiosity, since the pad on the LED is rectangular, did you choose to make the post round just because it was easier to do on the lathe, or were there other considerations?
I didn't notice if there was a separate power switch or not... I assumed that moving the ring would wake the micro up, which would require the halls to be enabled all of the time. .... or... just have the micro briefly power the halls every half second or so, looking for a change of state. I've worked with hall switches such as the Allegro A1101. Its datasheet says it draws 4mA typical, which would kill a battery relatively quickly.
It's always fun to contemplate other ways to implement a function... Instead of using an active device like a hall, an option would be to use a coil to pick up changing flux from a magnet ring. It wouldn't draw any power, and could be used to wake up the micro. The output voltage will depend on the speed of the changing flux, so it might ignore slow changes. This might be a bug, or it might be a feature. The downside is that winding coils is an extra production process that costs money and can go wrong.
best wishes for the project,
Steve K.
That sounds like a really good current draw, if you don't mind me asking, what's the part number? I've found unipolar or bipolar sensors with current draws around that level, but no linear ones that were acceptable for my purposes.
Can you post a video of the flashlight switch in operation?
Here are some videos I took tonight:
MagnetoDrive - moving of the control dial slowly
MagnetoDrive - moving of the control dial at normal speed
MagnetoDrive - moving the control dial very fast – a "flick" to achieve max brightness - "turbo" mode!
The first post has 3 videos where you see me moving the switch in operation on this mule/prototype - that is why I had that small piece of blue tape in the videos so that you guys could see the movement.
Once I have the second prototype (closer to final design), I will make new videos.
Will
PS - thanks Nitroz, you were quicker with the reply
Nice work Will
that magnetodrive could be used also as throtle on scuba scooters ;-) special on brushless drives
