Th232
I hope the patent is more than just US only, I'd hate to see you lose out in the international market.
Agreed! :thumbsup:I hope the patent is more than just US only, I'd hate to see you lose out in the international market.
I am definitely covered in the USA, as I filed prior to revealing my invention here, but now that the information is in the public domain by this post, technically, no-one else can file in any other countries and claim they are the inventor, as this information is now available publicly to 100's/1000's of folks world-wide. Then again, not everyone follows rules nor have the same moral standards than most of us doAgreed! :thumbsup:
Thank you. The cone idea came to me when I was done with the machining and put all of the parts together. With the OEM Mag head, the mule/prototype just did not screamed "custom" enough, plus the dial and rings in the middle had straight lines, so the head's curvaceous surface kind of looked out of place, so the idea came to me to try to give the head a straight cut, and the result is what you see here in the picturesIt's a brilliant idea that takes variable power control to the next level.
The light itself looks very cool too - I really like the cone/venturi shape of the head.
Yes, with an external MOSFET and a few discrete parts, you could use the MD controller board to provide dimming to an incandescent bulb. I have it in the code today to have an inverting output, so the PWM can work active LOW or active HIGH (I needed this for LED drives since different drivers have different PWM active modes). Of course, this would not be a "regulated" combo - it would still be a direct drive configuration, but you would have 0-100% dimming, and the same access to all 255 steps as in the LED case, depending on how fast you move the dial.And by the sounds should work for LED and Incan as well. Variable "analog" hotwire driver, wow.
Since I am the programmer/designer/machinist/tester/etc., the process is unavoidably slow, but still moving forward
Will
True, I am also the HR department so nobody gets paid until I say so :devil:Yeah, but I bet you have no employee disciplinary issues nor contractor problems!
Thank you. No sign up list yet - a little early for that. I need to finish the second prototype. I will keep this thread updatedNICE!!
So wheres the sign up list
That is true. But I am also the HR department, so no-one gets paid until I say so :devil:Yeah, but I bet you have no employee disciplinary issues nor contractor problems!
Bit of server lag going on there I guess.....
I already contacted an admin to delete the extra posts. Quite embarrassing as something happened with my browser and the CPF database since it keep timing out, and I just keep trying. I should had stopped and waited before trying againNo Will is just trying to bump up his post count. :nana:
Thank you. Yes, the host that I am designing is a dive-rated host from day one: no push buttons of any kind, dual o-rings on the tailcap, and with a thicker lens (shooting for 1/4" thick lens)/o-rings up front to withstand actual diving use. Right now it will be built around the 26500 or 26650 cell size, so it would make a great main or backup light while diving. But I am planning on an even shorter version (basically head only) to that it can be used with a canister for longer dives, but that could also be used as a bike light (head separate from the battery pack).Will, threads and accomplishments like you just showed us remind me why I need to come read here more often. Just incredible....and this is going to also work for diving when you work out prototype issues? What diving depth are you striving for? WOW!!
LOL, I've now deleted the duplicate posts. Sorry for the delay there, Will - I've been away for ~2 weeks.Will is just trying to bump up his post count. :nana:
