Albinoni
Banned
Also, here is something about using 14500 at 100% brightness level, thanks to the drive of I.B.S. circuit, this light can reach 225 Lumen when using only one 14500, instead of 2 CR123 batteries to achieve the same brightness level. And as known by all, 2 CR123 battery type of flashlights maintain only 1.5 hour of runtime at Max (225 Lumen). Therefore, to our I.B.S. circuit, which using only one 14500 battery (electrical power equals to about 1/3 of that of 2 CR123 batteries), half an hour of the runtime at 100% brightness level is fairly reasonable.
Hi JetBeam, now re batteries for both the MK II I.B.S. and the Jet III Pro I.B.S., is it possible to use Sanyo Eneloops in these torches ?
Also the Jet II I.B.S uses a 1xCR123A battery as I believe, but if all three torches use the same circuittry, than why is the Jet III Pro the brightest when the Jet II has a 1x CR123A battery which is a 3 volts batt. Sorry bit confused here.
Also will the Jet II accept rechargeable type CR123A batts.
Thank you
