M6 4xMC-E (+LedZep HS +FM3 Head +6x17500 + + +)
petrev
SW England
Hi
Finally got all the parts together
SF-M6
LedZep MD-4MCE HeatSink (Modified)
LedZep M6 Cone Adapter
4x McR27S
4x MC-E
1x SharkBuck-3A+Remora
FM 3" Head
FM M6-MagD adapter (Modified)
Petrev 6x17500 battery carrier
M6 Short TailCup
Heatsink and Cone
Heatsink needed 2 extra holes to attach the cone (and the screws)
5.5mm deep bore machined into base of HeatSink to fit Cone
Assembled HS + Cone
Fit into M6 to check !
Epoxy 4x MC-E at 22.5º rotational offsets to avoid coherent interference (?)
Little white tool provided by LZ to centre LEDs
Fit SharkBuck3A-Remora into Cone
M6 to Mag-D Head adapter supplied by FiveMega
Needs modifications !
Cut O-Ring Groove - Helps to prevent water ingress ! ? ? FM ?
Re-Bore to correct 34.20mm Mag-D inner bore
Cut Slots to facilitate adapter removal from inside of 3" head !
Solder connect LEDs
Power Pack !
Fit a 3" Head - Now on it's way to the Anodizers for HA-III
Another head also off to the Anodizers . . .
Fit up a Black FM3H-2 for now
Really easy to swap between heads
You Beauty ! ! ! Love my M3 (SuperTurbo) MZep-7XRE too . . .
Cheers
Pete
Re: M6 4xMC-E (+LedZep HS +FM3 Head +6x18500 + + +)
Nice work and perserverance Pete!
Thanks for pioneering this adaptation.
Nice write up & great build, Pete! It looks like a monster. I can't wait to see beamshots! :hitit:
I have one question, and one comment:
Question: How do you fit 6x18500 li-ions in a M6 body?
Comment: I love how you rotated the mc-e emitters at 22.5 degrees to fill the X void that we typically see with quad-dies.
Thanks for all the great comments guys :thumbsup:
Hi Maxspeeds
17500 cells only ! 18mm cells won't fit.
My Custom built 6x17500 carrier and the STC (ShortTailCup)
They are in my thread HERE
Hi nanotech17
Yeah - Even better looking when the head gets back from the anodizer
:cool:
Your carrier is awesome. If I had an M6, I'd definitely have that setup. I guess I was confused by your title, "Re: M6 4xMC-E (+LedZep HS +FM3 Head +6x18500 + + +)"
:oops:
Sorry - That would be slightly misleading !
Corrected - Thanks for the spot
Cheers
Pete
