ElectronGuru
I cant believe I went to Target, Lowes, and Home Depot and nobody had a 3C maglite!
Thank god for Amazon.
My favorite Mag dealer:
http://www.zbattery.com/Flashlights/2C-4C
I just put mine in my Maglite 6D. I like it, almost too much flood? I'll try to borrow a camera to take some pictures.
Does anyone have a "DIRECT" link to a place I can buy an aspherical lens? Do I need anything else besides the lens to make it work?
All of the links in the previous thread are broken.
I found this one,
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1753
Would that work?
Hi folk,
I received the Malkoff P7 Drop-in (Mag D) and killed the LED after first switch on :hairpull:.
The 14V power of 9 AA primary batteries (fiemega´s 9AA battery holder) destroyed the P7 immediately.
Next time I will use 9AA rechargeable NIMH batteries with ca. 11,5V. Now I will gauging it before. Are 8AA better?
Now I am on the way to repair the drop in. I think this rescue effort is the trouble worth because all other parts of the valuable drop-in shoult be ok.
But I need your help to buy the right components. I never modded a flashlight before.:help:
*) Do the driver unit survived the breakdown?
*) What sort of P7 >bin code< shall I take?
(CSWOI,CSXOI,DSWOJ...?)
*) Is the little metal plate under the P7 added from Gene or a original
part of the Soul P7?
Thank you very much for your help!
Greetings
Has anybody tried a smooth reflector?
I am using the D size P7 dropin with a smooth reflector. The throw is ugly.
I am not impressed with the light considering the cost. It is bright, but from 50-75 yards, it is not significantly brighter than my generic Q5 running on 6V. I got the 9AA to 3D adapter from fivemega (its a nice piece of work and well worth the $39 pricetag) and a set of eneloop batteries. The P7 is significantly brighter than the P4 Malkoff dropin and that is known to throw a beam, but I cant justify the price considering how it only marginally outshines a $20 Q5. I have an aspheric lens on the way, maybe that will make this thing worth playing with. Also bought the crenalated bezel from Malkoff, its nice, again, not sure if its worth the price, and I dont think it will fully protect an aspheric lens.
I guess I do not understand why you chose a P7 drop in that is know to be a non thrower. There are plenty of drop ins that will out throw the P7. I do not own a P7 drop in or any P7 setup. I have done much research on the attributes of a P7 light, and a thrower it is not, being more of a high lumen flood.
Bill
I was aware of the P7 beam characteristics, I guess I was just hoping for a little bit more WOW factor. The P7 just didnt do it for me, especially compared to an un-named $20 Q5 running on 2x CR123's. I thought the P7 would really blow it away and it just doesnt do it for me. Its definitely brighter, but as far as useful light, they are really too close to call. Ive only tested on a treeline 50-75 yards off, so the yellow tint of the P7 might be the culprit. The Q5 throws white, so it is easier to distinguish what you are looking at considering the green and yellow background of the trees and shrubs. There are plenty of beamshots out there but with my experience the P7 underperforms and the Q5 overperforms. Who knows, but in any case, it was a pleasure doing business with Gene, the order shipped promptly and everything was well packaged. I also appreciate his generous CPF discount. I do like his P4 dropin and highly recommend it. With the advances in small CR123 powered lights, something in a 2-3D size application would need to really be special to stand out. Just my 2 cents.
Im thinking about getting one of these for a 2d when they are available. Do you guys replace the stock lens and reflector with something better? I thought about the 2 18650 option any other suggestions? Will a123's fit in a 2d?
I use PVC pipe cut to length and adjust the spring length.
For 2x18650 in a 2D light I use 3/4" PVC with half of a coupling on each end to center it in the flashlight.
I make a series of them end-to-end and then saw through the couplings. I can make quite a few in a short time. A tiny amount of adhesive before sawing to keep the coupling on. (I mount a fine tooth blade backwards on the saw for a clean cut.)
Overall length (not all that critical):
2D (2x18650) = 5" (127mm)
3D (3x18650) = 7 1/4 " (184mm)
To run 4C's in a 3D Mag body I use 1" PVC cut to 7 3/8" without couplings. I cut a few more of these while I had the saw set up.
Rich
For example:
