I was wondering if anyone knew the approximate mA's for the different levels in the UIB, how to work them out. Also the same for the 3 emergency low power settings
The Maxflex is set up with the current selected at 1000mA
Close - but NOT right. You have the CONTROL SWITCH wired wrong. It needs to go from SW to ground... STAT is for the voltage status LED/resistor.
cheers,
george.
