Neat household MacGyver tricks you've learned
PhotonWrangler
In a handbasket
This is kind of the opposite of the Things I've learned the hard way thread. Have you learned of any neat little triccks where you've used household materials for uncommon applications?
I've just learned a trick that helped me out with a cracked fingernail that was getting close to splitting all the way down. You can use the material from a teabag as a patch, covering it with acrylic fingernail strengthener to form a conformal patch that halts the splitting.
What neat little tricks have you learned along the way? :popcorn:
If you have cookies that are not soft anymore, just put a piece of bread in the cookie jar or bag that the cookies are in. The moisture in the bread will be absorbed by the cookies. Overnight, your cookies will be soft again.
Not a MacGyver trick, but that's one from my mom.
My dad invented an A/C circuit tester for tracing down which circuit breaker was on a circuit so it could be shut off to work on it safely.
Lifetime warranty, Craftsman screwdriver!!
Here is my memory... He is on the ladder at the ceiling junction, I am at the panel flicking breakers and we are yelling back and forth, ' OFF!!'
"NO, try again!!" his reply. He finally just used the screwdriver to short it out in the junction, thus popping the breaker and us not having to yell back and forth anymore.
Disclaimer: this was 25 years ago, the quality of said screwdriver was obviously far superior in dielectric qualities than stuff today.
So is this a MacGvyer trick I use, Not on your life!! My dad was a superhero, I am only human, I could get hurt 🙂
Russ
I've used a pair of headphones to locate a live video cable in a bundle of similar looking coaxial cables. The combination of horizontal and vertical sync pulses produces a very unique sound in the headphones that's like nothing else. Once you've trained your ears for this, you can 'hear' the presence of video. 🙂
Is there anything that can't be fixed using ductape, zip-ties, a can of WD-40 and a SAK (or a combination of those items)?
Yep! You only need two things in your repair kit - WD-40 and duct tape.
If it doesn't move but it's supposed to, apply WD-40. If it moves but it's not supposed to, use duct tape. :laughing:
:crackup:I'v use Gorilla Duct Tape to fix a ripped a pair of shorts from the inside,...its stayed 'fixed' though many washings.
Strong stuff!!
When I was a 'kid' I accidentally took my 'old' used razor and not a new one on a trip. We were at a camp ground and the twin blades got clogged pretty good, so I took a Q-tip, pulled off the cotton, flattened the cardboard tip and used it to clean out the razor.
:crackup:
I've got this plastic cable tie (maybe 20" x 3/8") that I use to unclog the shower drain. It snakes down into the drain easily and won't damage the plastic pipe.
Geoff
A way to keep eggs fresh outside the fridge:
turn them upside down every day.
Heard this years ago from in program about sailing around the world.
Garlic smell:
To get rid of the garlic smell on your hands you can use a metal soap.
(I think a piece of metal will do the job too)
Snails in the garden:
beer
Put some beer in a small box (tupperware or alike) and place it in the garden.
Snails like the smell of beer and will crawl into the box and drown.
Nasty sight, but effective
Flies in your kitchen:
Bowl of water with some vinegar and a drop of soap
Garlic smell:
A piece of stainless steel, rubbed on the hands while you wash them, removes all kinds of smells, like garlic and onion.
