Maybe if you want either to get a really tight beam, or have a really small form factor light the size of the dome and the ability to have a smaller reflector is interesting. I'd suggest that for any other application (which is the majority) it's not actually that useful.
Meanwhile I'm not convinced there is any evidence of "anti-droop" technology in the data-sheet. Looking at the graph on page 16 of
http://www.lumileds.com/pdfs/DS56.pdf it seems you only get 2.1 times the lumens at 1000mA compared to 350mA, which is no better than an XR-E, and worse than a SSC P4. Then again, that also contradicts the info earlier in the datasheet, as the figure for 700mA is no better than 1.65 times (again not significantly better than an XR-E), which would imply ~130lm for the 80lm nominal part, not the 145lm they claim. I'm not sure whether this discrepancy is down to different testing regimes, bearing in mind that Lumileds are reported to test using extremely short pulses, which is bound to overrate the higher current performance.
Also given that P4 bin XR-Es have been tested at 145lm at 700mA (Q2 bin now available), and SSC P4 at 155lm, that 145lm for the
best bin is nothing special.
