Re: New Mag C-cell incandescent twisties: M25IT
YOU HAVE BEEN WARNED ALOT OF PICS COMING UP.
I completed the Stinger reflector mod. It does require a lot of fiddley work to make it fit. To do mod you will need a few tools.
* Sandpaper ( ALOT )
* Files
* Vice
* Drill press
* Press
* Tool to remove reflector from stinger bezel
* Most importantly ALOT OF PATIENCE
This is Version 2 which requires a bit more work but will mean you can still use mag reflector again. Will show version 1 at end.
Press reflector and lens out of stinger bezel with a suitable sized piece of tube, washer and socket.
[/URL][/IMG]
Secure bezel to a block of wood with a washer on the inside. It will catch on the lip on inside of lens.
[/URL][/IMG]
File away bezel to bottom part that holds the reflector in. I used a sanding disc in a grinder to speed things up a bit
[/URL][/IMG]
Sand to a flat finish with P600 sandpaper
[/URL][/IMG]
Next Step is the hardest. You need to Machine out side of bezel to fit down in to mag head. You will need to leave a 3mm deep lip a top, this is the depth of mag lens and reflector lip. This is what mag bezel will screw up against.
[/URL][/IMG]
Sand away bottom of reflector to allow room for reflector to focus on bulb
[/URL][/IMG]
I have replaced plastic lens with a nice AR coated glass lens. Couldn't get correct size. Taped up both sides of lens and sanded down till perfect fit. I pulled lens and rotated a same time. Works great and keeps it round. Started with P120 and finished with P600. Make sure to spend plenty of time cleaning it for once you press head back together you can't clean inside of it again.
[/URL][/IMG]
Put lens in bezel and press reflector back together. This is the finished unit.
[/URL][/IMG]
You will need to remove about 3mm of inside head threads. This is to allow head to screw down far enough to focus bulb. If only reflector had been 3mm longer.
[/URL][/IMG]
That's it completed. With this version you can switch between mag reflector and stinger if you want. For now I am not twisting head to turn of and on. I like to keep bulb focused and turn tail cap to turn on. If you screw cap of a turn it will work like a momentary switch. Will look into making a tail cap switch.
[/URL][/IMG]
[/URL][/IMG]
Beam is not completely round. A bit oval. Still throws well. Put a few sets of batteries threw it with a 6d bulb and so far its working great. In the 3c body might try a 12v bulb if I can find a suitable one. That should relay test it out.
[/URL][/IMG]
This is ver 1. As you can see I sanded down Mag head bezel threads to allow more room for stinger bezel. This means you can't use mag reflector again but means a lot less work is needed to make bezel fit mag head. I like ver 2 better as it leaves mag head nearly as standard.
[/URL][/IMG]
Not an overly expensive mod especially if you use the stinger plastic lens. I tested the plastic lens and it holds up to the heat of a 6d bulb on 2 imr 26500 ok. I went glass as I might try a better bulb Later on. Have a TL-3 bulb coming and I am hope full of a better beam pattern from it over a 6d bulb. Funny thing is a put a 5d bulb in and it give a great pure white round beam. Don't know why 6d bulb should be a different beam shape ?
