DimeRazorback
I don't think it was his fault... I believe it was a manufacturing mistake which is also costing Gene as not many people will by the head now!
The unit is intended to be turned on/off by rotating the 2 body pieces into each other. This is because the e series design relies on the top of the battery tube to make contact with the bottom of the lamp/module/etc with just over 1/4" thread engagement, it was designed by SF to be threaded all the way in and left there, with just enough counterbore for the oring to set in. What that means is that the oring point between the top of the tube and the bottom of the head will not seal properly if unscrewed too far. This 2pc body design allows for the body to be unscrewed far enough to turn the light off (especially when you consider not all batteries are the exact same length) and still retain water resistance.
If I use the threads between the head and body, the O-ring is still completely covered when off, and there are no rattles at all, because the spring is compressed. This may not be what was intended, but it is the way I will use the light.
Just the bodies (and a bunch of other stuff ) are available at JSBurly's
... I found that my head could be tightened a great deal more than I had it. ...
Forget what I said before, this is a non-problem.
