SaturnNyne
prime77: It sounds like you're getting into the options menu and then just clicking the button 9 times as fast as you can. This results in what you're describing, I tested it on my 120P. What you need to do is get into the menu with the 250+hold, then let off when it starts flashing. At that point, you can relax, you have about ten seconds before it kicks you back out due to inactivity. At that point, you just need to slowly click, from one item to the next, to step through the various menu items until you get to the one with the light ramping up from dim to bright, which happens to be 8 clicks into the menu since it's the 9th option. When you get to that, just hold down the button until the light turns off and you're done.
