MattK
Since it seems that TigerhawkT3 doesn't know when to quit I'll play his game. I apologize to anyone who is interested in the actual discussion that was occuring in this thread.
-"The Gladius can start its constant-on from its highest output, its lowest output, or the last output you used. It also seems to have better electronics, with smoother regulation and timed step-downs for extended use. It also has a depth rating of 50m."
Timed step-downs that occur after the output has already dropped from thermal heatsoak. Not an issue with a properly heatsinked light like the Striker.
-"What's that supposed to mean? Does the Striker VG have a super-bright GITD around the opening of the battery tube?"
No, since "Reattaching the tailcap is a process that needs to be executed properly to prevent damage to the light and possibly rendering it inoperable." (FLR) isn't an issue as battery changes are a simple matter of unsecrew, insert, unscrew no GITD opening or additional lightsource is required to keep you from rendering the light inoperable during a battery change.
-"If by "you," you mean me, as in TigerhawkT3, then you're wrong. Perhaps YOU need two hands to change modes, but not everyone does."
Really? Let's play police. You have your light on a suspect and your concerned he might be going for his gun. Do you tap three times or do ask Mr Criminal to wait while you holster your gun, twist the tailcap from postion 3 to position 2, remove your weapon from the holster, reaim your (finally strobing) light and reaim your gun?
Let's have a video of you switching modes with one hand while keeping the light fixed on a target.
-"I'm not a soldier, and I'm not on a SWAT team. I'm an armchair commando, a mall ninja. I'm certain that the Gladius would be perfectly suited to use by security or police officers."
I'm none of those things but we have LEO's in here almost every day of the week and I've had many lengthy conversaations with them about how they USE their light on a day to day basis so I get firsthand information on a regular basis.
-"Also, FR gave the Gladius 5 stars, while the VG received 4.5."
True, of course QB reviewed the Striker 6 months later and despite the lower score ranked it higher among the 3/5W lights in his top picks.
-"I'm sorry you feel that way. From what I've read, the Gladius is more high-end, but I haven't tried a VG myself. I'll see if someone can bring one along to the next CPF get-together in my area."
Again, you're claiming the Gladius is superior yet you've never even SEEN a Striker never less handled one or used it in a situations for which it is designed.
-"I didn't describe how it's better in that first post because I thought it was obvious, but it seems not."
How is it obvious that a more expensive light with less throw and less output is inherently superior? Because you own one and need your expensive purchase to be validated?
-"I wish you would do the same. A lot of the things you said about the Gladius and its differences from the VG were incorrect."
Like what? I have at least stated my case withot resorting to childish and malicious name-calling.
-"Dear lord, not this again. The Gladius's channels add ONE STEP to the procedure, and it takes about two seconds: Aligning the tailcap before tightening."
An act that if done improperly can render the light inoperable and thus requires a light source to be done properly. Not sure that's the light I want in a life/death situation.
-"So, is perceived snide a reason to start hating someone? "
I don't hate you - I don't CARE enough about you to waste the energy. I'm only replying because you are calling me a liar and my reputation is important to me. Frankly I probably don't need to worry - you should see some of the IM's I've gottten in support since you posted. Apparently some folks here do not think so highly of you.
-"I would NEVER have expected such a response from a business representative like yourself, but now I know better. "
Clearly at 20 years of age you haven't had much business experience.
You keep calling me a liar yet where did I lie? Again, just as in your very first post in the thread, you make a point then fail to back it up.
Are we done now?
Again, my apologies to the rest of you but I can't stand idly by while someone calls me a liar.
Are we done now?
