Hi All,
I haven't been as "flashlight oriented" for the past few months and as a result, haven't always had a SureFire or NiteCore or other larger flashlight on me. Because of this, I have been using my Fenix LOD w/ Eneloop almost exclusively as that is what is always with me. I am more and more impressed with this light all of the time. I think this light could easily cover 95% of what someone needed a flashlight for in terms of everyday use.
Some of the things I like:
-Very good brightness. This Fenix puts out enough light that I can use it when I take the dog out at night or walk down to the neighbors. I know we are spoiled by 500 lumen flame throwers, but this light is more capable than the 2-3 D cell flashlights that most "normal" people use.
-Mostly smooth finish. I can't tell you how many cell phones, wallets, and other pocket gear that were chewed up by the Arc AAA I used to carry. I like being able to toss the light in a pocket WITH OTHER THINGS and not worry about it.
-Reliable. I've had the light since it came out and it hasn't given me any trouble. It seems just as reliable as any other flashlight I've ever had.
Some things I'd like changed:
-Make the body just as small as it can be. This includes making a "pocket" body without the extra metal on the end for a key ring as well as making the walls thinner. I carry the light loose in my pocket and the end for a key ring gets all sorts of lint and dust in it. Also, the key ring cut out is sharp and has worn down to the metal. Regarding the wall thickness, I carry this in my pocket and don't need it to be as strong as it is. I would take smaller size and not quite as bomb proof. I know people will say it is needed for heat dissipation, but I'm holding this light in my hand. I'm sure as long as there is a good thermal path from the LED, my hand will be enough of a heat sink.
-A Turbo level with a newer LED. With the advancements in LED technology, I would like to see a new version that had a 4th "Turbo" level that put out around 125 lumens. Take out the SOS feature and put this Turbo option in instead. Even if runtime was only 15 minutes, it would come in handy.
Thanks for reading and thanks to Fenix for putting out such a great product. I can't wait until the above version exists!
Thanks,
Robert
Thanks,
Robert
