VanIsleDSM
P60 QUAD Information thread:
http://www.candlepowerforums.com/vb/showthread.php?t=299178
Specs:
Precision machined to fit genuine surefire and FM26XXX P60 hosts.
Single Li-Ion cell operation for energy density and safety.
LEDs individually current regulated.
Integrated thermal shutdown.
Reverse polarity protection. Upside down battery causes no harm.
2KV ESD protection. Resistant to static shock from your fingers.
Low battery warning (drops to low mode and intermittently flashes off quickly).
Mil-Spec Teflon insulated oxygen free silver plated copper conductors.
Silver plated beryllium copper ground spring with gold plated contact.
Gold plated positive contact.
Cushioned shock resistant driver.
Modified Khatod Italian made 10 degree FWHM (tested with XPE) beam. Tightest beam possible from P60 multi-LED engine. More common Carclo optics pictured for comparison are 16.4 degree FWHM. (Frosted version pictured)
Available Tint and Flux:
R5 Cool white 6200K
R3 Neutral 5000K
R4 Neutral 4000K
Q5 Warm 3000K
Available Driver Mode Configurations:
5 mode: Low - Med - High - Strobe - SOS
3 mode: Low - Med - High
3 mode: Low - High - Strobe
2 mode: Low - High
1 mode: High
5.6A silver plated copper Drop-in:
R5 minimum flux calculates to 1780 lumens.
R4 minimum flux calculates to 1665 lumens.
R3 minimum flux calculates to 1560 lumens.
Q5 minimum flux calculates to 1370 lumens.
Thermal Data:
C101 99.99% pure oxygen free copper thermal conductivity: 391 W/m · oK
99.9% pure silver plating thermal conductivity: 418 W/m · oK
LEDs directly mounted to silver plated copper surface. No MCPCB insulation layer. Lowest thermal resistance path possible without extremely exotic materials (e.g. diamond)
Artic Silver 5 thermal paste included for application in host P60 socket.
$310
4.2A Aluminum Drop-in
R5 minimum flux calculates to 1450 lumens.
R4 minimum flux calculates to 1355 lumens.
R3 minimum flux calculates to 1270 lumens.
Q5 minimum flux calculates to 1115 lumens.
Thermal Data:
6061 T6 aluminum thermal conductivity: 167 W/m · oK (Heatsink)
Pure aluminum thermal conductivity: 220 W/m · oK (MCPCB)
Bare aluminum for best conduction of heat into host. MCPCB screw torqued to 32 in-lb. creating a clamping force of over 1000 lbs. Arctic Silver 5 thermal paste applied between MCPCB and heatsink.
$165
FETtie high current switch
Information Thread:
http://www.candlepowerforums.com/vb/showthread.php?t=296127
Introducing the ultimate high power tailcap switch for Z41 and FM26XXX hosts.
Designed as a suppliment to the P60 Quad drop-in, This switch's capabilities extend well beyond it's originally intended necessity.
With ANY Linearly regulated or Direct Drive light, this will reclaim power currently being eaten by your higher resistance switch/spring, and give you more current, and more lumens.
With ANY Buck, Boost, or Buck-Boost regulators, this will reclaim power currently being eaten by your higher resistance switch/spring, and provide longer runtimes.
How does it work?
The FETtie uses a solid state semiconductor, a MOSFET. Essentially a relay, with no moving parts, which is turned on by the clicky switch. The Clicky switch itself only conducts 100 nanoamps, that's 0.0000001A, to activate the semiconductor. This means the clicking mechanism will last nearly forever, as the electrodes will not wear from arcing.
The FETtie uses a small coin battery, 1216 size. You do not need to worry about this battery becoming depleated however. It's like the battery in a watch, it will last for many years. Even being left on, the switch will draw less current from the coin cell than it's self discharge rate
Specifications:
Current - 25A+
Voltage - 12V MAX
0.0034 ohm Rds(on) MOSFET resistance
Beryllium copper spring, Pure silver plated for extra conductivity, 24K gold plated contact area.
Gold plated contacts from the FETtie to host.
Threaded brass body
Panasonic 1216 coin cell included
$48
Here are some graphs comparing it's performance to a McClicky switch with various cells using my 4.2A Quad drop-in. These results would be compounded with higher currents.
The graphs stop at 1.84A, a figure corresponding to 750 lumens, or half brightness of the drop-in.
Warning:
These lights can be dangerous. If left unattended it could get hot enough to cause a failure in the battery, resulting in a possible fire or explosion. Do not point light at eyes or skin. This is a very high power device. Do not run unattended.
Ordering:
All Drop-ins are customized to you, and are built to order.
PAYMENT TEMP. ClOSED. Next 10 slots will be open ASAP.
PM me if Paypal is not an option for you. I will also accept money orders.
Please include your CPF name, and your itemized order in the Paypal notes. This helps me keep track of everything.
I will be opening 10 slots at a time. The first 10 people to confirm and pay will have their order built in the order paid. After 10 orders have been completed another 10 slots will be opened.
1. Drywolf
2. kellyglanzer
3. ejot
4. Syncytial
5. OneBigDay
6. Glenn7
7. quadcree
8. nailbender
9. one2tim
10. X_Marine
11. J-Frame
Shipping:
$10 to USA, $15 internationally
Shipping by airmail, no insurance included.
Upgrade to expediated shipping with tracking and insurance for $25 to USA
Ask about international expediated shipping.
Within Canada it's ridiculous at the post office, I'll be checking a courier for the first person within Canada and let you know.
