ti-force
Well, I've been carrying a Quark 123-2 R2 Tactical for quite a while now, and I've just fallen in love with these lights, so I decided to buy a Quark 123-2 with the newer R5 emitter. Only problem is, the one i purchased had the Regular UI which isn't really my preferred UI, so I started thinking about modifying the light somehow. You know how flashaholics start to think:D, it's all over then:naughty:.
Anyway, I ordered some of the Shiningbeam 1.4A drivers, and then I let the modifying commence:devil:. As usual, I thought I'd share some pictures with anyone who's interested:
First things first, I opened the head up and removed the emitter/MCPCB combo. This is what it looks like under there:
This is what the driver assembly in the Regular UI Quark looks like:
Driver removed. It looks like a little smiley face.:
I decided to use the bottom board of the Quark driver as the contact point for battery negative and battery positive, so I had to separate the two boards:
Then I soldered and glued the Shiningbeam board on top of the bottom Quark board. I also added an additional 7135 chip; The devil made me do it:devil: haha... :D:
Glued the driver in:
Put some Arctic Silver 5 under the MCPCB for better thermal transfer and soldered everything back together:
The head is completely re-assembled. I even straightened out the emitter before re-assembly. It was slightly off center, now it's perfectly centered:D:
Now I have a new EDC favorite:naughty:. This light can be ran on 2xCR123 primaries or 1x17670. I'll probably run it on an AW 17670 most of the time. I measured the vf of my emitter, and it's 3.08v, so this light should run in regulation until the battery is depleted:candle:.
I wish I had another R5 head that wasn't modified so I could take some comparison beam shots, but I don't right now. Maybe I'll buy another R5 light soon, so I can take some comparison shots. Until then, I've taken comparison shots using a Quark 123-2 R2, Quark 123-2 R2 neutral white emitter and Quark 123-2 Turbo R5:thumbsup:
All pictures were taken with the same camera settings in manual mode and the Pine tree is about 23 feet from each light. I had to take the pictures with the lights in front of the camera because the camera wouldn't zoom out enough to capture all of the spill.
Control Shot:
Side by side:
*UPDATE* I now have another Quark 123-2 Tactical with an XP-G R5 emitter, so I decided to take comparison beam shots. Something I noticed immediately, is that my Shiningbeam Quark appears to have one of the XP-G R5's that has a wider hot spot:thinking:. This has been discussed before in another thread, but now I've witnessed it first hand. Also, I made a gif so it's easier to see the difference.
Control Shot:
Side by side:
