Hi everyone.
I have spent the last few days searching and reading as many threads as I can on the Seoul P4, and the light I intend to modify - the L1 Lumamax. I think I have it figured out for the most part, but I wanted to run my thoughts by you guys and make sure I'm not about to ruin my light. This must be painful for a lot of you guys, and I'm sorry to ask questions similiar to ones that have been asked before, but I want to be sure before I go forward.
First, I plan on keeping the TIR optic in place. I like the throw, and I when I want a flood I use the beam shaper or my U2. However, if I can bump up the output with the P4, the light will be all the more useful.
I also do not plan on changing the electronics - at least yet. I like the runtime, and seeing as though this is my first mod, I'd rather just screw up and have to find a new head than a whole new light.
So, to start, I plan on ordering a P4 from PhotonFanatic, as well as Arctic Alumina Epoxy.
My understanding is that I use vice grips + an old belt and heat to open the head. Once open, I desolder the LuxIII and pry/scrape it off. I remove any epoxy that is left, and solder the leads to the P4. Then I use AA and epoxy the new LED on to the heatsink. After that, I test fit the head, and use a dremel to shave anything back that might be in the way. If everything fits, I screw the head back on and I'm set.
So ... am I close? I apologize again for the basic level of these questions.
