Sold/Expired SOLD: FiveMega D26 Bi-Pin socket Incan P60 Adaptor with FM1794 Bulb
ma_sha1
CT, USA
FM D26 socket with FM1794 bulb installed.
http://www.candlepowerforums.com/vb/showthread.php?t=190833
This thing is really really bright on 2xIMR16340. It has only been run probably a total of 5 minutes or less. There are a few "spots" on the reflector which was how it was received and since it made no noticeable artifact or problem in the beam, it was left as is. Included the little washer to provide better contact in some hosts. For some other host, a negative contact spring may be used. I used a spring to fit my SolarForce L2 (the one with 18mm battery tube) Running 2x18350 Li-ion & it gives ~1.8 Amp battery draw.
This thing will make your P60 host brighter than ROP High:naughty:
$25, including the FM 1794 Bulb
PP fee & Shipping add $4, USA Only.
Re: FS: FiveMega D26 Bi-Pin socket Incan P60 Adaptor with FM1794 Bulb
Moddo was looking for this exact set up.
If Moddoo doesn't take it I will.
HEY!
QtrHorse, curtispdx, thanks guys.
I'm just getting my feet wet with some of this incan stuff.
I'll take it.
:twothumbs
Moddoo, you should use a soft start switch (just in case you did not know).
I have this same reflector and bulb. I run mine off two 18650's and it is really bright.
Great news,
I have a soft start to use with this.
I was wondering what cell combo would be safe.
I saw a lot of loyalty here in this thread! :twothumbslovecpf
SPF...
payment sent.
thanks again everyone.
lovecpf
Thanks, Will ship tomorrow.
