Mr Happy
I read it the same as you do. Hence your circled resistor does appear to be R13.Am I understanding correctly ?
Just double checking , dont want to build a bomb by mistake ...
march.brown,
in the CV stage the Soshine does not push a current into the battery.
It is a constant voltage source with an output impedance of approx. 180 milliohm.
The current is a result of the voltage difference between the off-load voltage of the charger, the resting voltage of the battery and the sum of the resistences of charger, battery contacts and internal resistence of the battery.
From your graph, it seems that the charger is still "pushing out" about 180mA during the constant voltage part of the charge ... I realise that the charge current is due to the charger voltage being greater than the cell voltage and that the internal resistances of the charger and battery etc do have a contributary effect on limiting the current, but the charger is still supplying the current and when this current reduces to less than 30mA the Blue LED should come on.
.march.brown,
probably I was just using the wrong words.
It's more than 25 years ago that I learned English at school and I don't speak or write English very often.
I spend more time looking up words than actually writing.
That's why I like to add photos or graphs to my posts.
Of course the charger is supplying current in the CV part of the charge algorithm. When I wrote that it's not pushing out a current I only wanted to say that the current is not controlled or regulated by the charger as it is in the CC stage.
In the CV stage the current is determined by the voltage difference and the sum of the resistances of charger, battery contacts, protection curcuit and battery.
The internal resistance of the charger is quite high, that is why the voltage measured at the contacts of the charger is not really constant during the CV stage. I would call the whole region above 4.05V the CV stage.
I'm just discharging a 18650 and will post a "normal" charging graph soon. I hope that will help to clear up any misunderstandings.
That does not only apply to cheap charger but also to the good and expensive ones because there is always the internal resistance of the battery..
It would seem (to me) that some of the cheaper Li-Ion chargers work on this difference in voltage (between the charger and the cell) to charge the cell ... A higher current at the beginning of the charge when the battery volts are low then as the battery volts build up to about 4.2 volts, the charging current reduces to a point of equilibrium where the battery volts gradually becomes the same as the charger volts ... The battery volts will never actually reach the charger volts but gets within a few millivolts ...
A high output resitance of the charger will lengthen the duration of the CV stage.
A good bench power supply has an output resistance near zero and will need far less time for the CV stage than the Soshine.
But the Soshine is already much better than the HXY-042V2000A "Digital Li-Ion 18650 Battery Charger".
Here is a charging graph of my #2 Soshine:
The charger is not modified, I measured an off-load voltage of 4.247V
The battery I used is a black and red Trustfire 2400mAh that I discharged to 3.0V.
To avoid any additional resistance I measured the current as voltage drop accross the internal current sense resistors of the charger (~198mV/A).
After 250 minutes the LED turned blue and I removed the battery from the charger but kept it connected to the voltmeter for two more minutes.
The maximum voltage at the end of charge was 4,238V.
The voltage dropped to 4.230V within the two minutes after taken out of the charger.
Half an hour later it measured 4,227V.
At the end of the CC stage, after 103 minutes, the battery is already charged to nearly 70%. The last 30% take much loger to charge.
The curve isn't prettier, its better.Just because the curve is prettier? In the real world my XXC (Euro version of HXY) has exactly 4.20 volts open voltage on both terminals (so no modding needed) and charges an 18650 cell in four hours just like the Soshine.
