brightnorm
- Joined
- Oct 13, 2001
- Messages
- 7,160
Re: Streamlight TL-3: Clever design addresses issu
[ QUOTE ]
McGizmo said:
BrightNorm,
I haven't seen the TL-3 but I do have a TL-2 (impressive light in its own right). If the TL-3 is designed similar to the TL-2 I question some apparent possible contradictions in your comments on thermal management??
"Clever design yields excellent heat control. Bezel contains reflector and unique floating, shock-isolated LED assembly. Very thick aluminum head functions as effective heatsink, aided by slim but long body. One piece head/body."
Now I am confused how the module can be shock isolated and yet thermally connected? The TL-2 has a LED module that makes a hard and forced contact with the battery tube at one end and the reflector at the other but essentially floats within the head. Is this also how the TL-3 is designed?
Now here is a quote that I find rather interesting:
"....because rapid heat buildup in the KL4 and McModule makes sustained tests impractical..."
Ultimate steady state temperature of the light will show how effective it is in passing the heat off in convection and radiant forms. I agree that the TL-3 having more surface area should have a lower steady state temperature than the other lights. However since you have stated that the KL4 and McModule have rapid heat buildup, I think you have inadvertently identified these lights as having superior thermal management over the TL-3 if I may suggest that removal of heat from the LED qualifies as superior; not hand hold ability. I can make you a Titanium flashlight with a thermally isolated battery tube that will take forever to get warm. By the time it reaches steady state, the poor LED will be sweating bullets.
- Don
[/ QUOTE ]
Don,
Because of my non-technical background I may use inexact terminology. I'll answer your questions as best I can.
Exactly, it is relatively isolated from shock because it "floats" on that spring assembly
The difference here is that I am functionally orientated to the user, rather than to the way heat disipation cools the LED. It has always seemed ironic to this layman that the more efficiently a light thermally protects its LED, the less hold-friendly it becomes, as long as you are trying to keep the light as small as possible.
I wonder if there is a solution to this problem. Would very efficient LEDs be a partial answer? For instance a 300 lumen 5 watt LED producing 60 lumens per watt, and run at 1 or 2 watts. Would that allow it to run "cooler"?
There are times when I wish I had an engineering background, but my poor math skills make that impractical.
Thanks for your input Don, I always learn from you.
Brightnorm
[ QUOTE ]
McGizmo said:
BrightNorm,
- Don
[/ QUOTE ]
Don,
Brightnorm
