Re: SureFire M6 rechargeable options – SHOOTOUT
@ DM51: now you tempted me to buy an M6 :green:
I always regarded it as "non-practical" because of powering-problems, but whoow, since I read your most-extensive thread on the M6 I've ever seen, I changed my mind.... drastically! Now I want one :green: :green: :green:
Without going through all these pages of replies, I've got one single, but important question: there seem to be no less than FIVE original MN-XX lamps around, only two of those are originally intended to be used with the M6 (correct me if I'm wrong here).
The question is: which lamp has been designed for which voltage (or number of series-connected primary CR123s)?
I'm not looking for the last Lumen to squeeze out of it, I want to be on the safe side, and I want a decent runtime (about an hour or so, a little less is OK) so I thought of using the 2X 18650 holder. A bulb that has been designed to run on 3X primary CR123s is right in this case, isn't it? If this is no good (no matching MN-XX lamp) I can also use the 3X 16760 holder, but I think, there's no lamp to match this one in the SF-assortment.
Alternatively, I could use the Lumens Factory bulb, this one has been designed to operate on 10.8V (that means: 3X Li-ion in series) so, in this case the 3X 16760 will do?
There's no 3X 18650 holder, as this won't fit I suppose?
Final question: I see, this LF-bulb also throws out 700 Lumens, just like one of their D36 dropins for the M90 Rattlesnake.
Do you have any idea on how these two lamps will perform, does one have the better throw, spill, overall brightness out of the front etc etc??
If they are quite equal, there's little need to buy an M6... I already have an M90 with the conversion kit ("150" extender, three batts, charger etc etc).
Timmo.
