DM51
Re: SF Titan T1A tints?
I'm merging your post into another recent Titan T1A thread.
So-called "white" light LEDs produce very little red light.Any ideas where to get filter attachment compatible with T1A?
I am thinking of using it as a headlamp (on the side of headband) with optional red filter.
Using a red BeamFilter to remove everything except for the red light will result in a very dim red light.
I think it'd be more effective to purchase a dedicated Red LED light such as a Princeton Tec Pilot (Red) which is specifically designed to attach to a headband.
Thank you for your advise, Al. I did not know that Pilot is available with red LED. Will definitely get one.
I understand inefficiency of using a filter instead of emitter of desired color and already waiting for arrival of ZebraLight H501R.
The idea of continuously regulated red light fascinates me and I really like to experiment with it.
Usually the amount of red light required is very low. Thus dim output with filter should not be an issue in this case.
Depends. It's said that LED's put out monochromatic light - well I doubt it's as monochromatic as a laser pointer, but if it IS truly monochromatic you'd be getting practically nothing once you slapped a filter on there.
Long ago I tried putting a piece of blue glass in front of a red laser pointer - it may as well have been opaque black...
EDIT: I still don't understand how white light could be monochromatic though - "not full spectrum", yes, but IIRC you can't get white light without mixing colors...
Same here, I've went through the various Titan T1A threads and thought this was the best one for adding my experience & thoughts with my new light.I am using Sean's thread to talk about my T1A's. [...]
Well, I know SF doesn't worry that much about our little troop of flashaholics over here, but I figured I'd lob a suggestion over just for the attempt. :shrug: I really do like this light, but it would be so easy for SF to perfect it at the manufacturing level rather than folks having to do it here.
I hope mine doesn't exhibit the donut in the beam you're referring to, but if it does I'll now be prepared. I think providing feedback to manufacturers, even when we feel like it won't be heard, is extremely important. If no one ever tells them then it definitely won't be fixed. So pumped to check out this light!!!!!
Agreed 100% - DaFAB did mine as well. Bernie (Kiessling) had his done too. HUGE improvement!+1 on DAFABRICATA mod, he did a perfect job, and the light is 200% more useful, and the low is still low low.
If you are unhappy with the tint of your stock T1A, consider dropping Dafabricata a line. Not sure how often he does these mods, but I'm extremely happy with my T1A.
I am looking forward to your comments after you turn your T1A on. Both of mine had the focusing issue, and I sent one off to "Laser" for a fix, and a more neutral tint Seoul. Turned out really nice, but it would be nice if the fix was not needed.
Bill
