I believe it does but I can't notice it at all. Thanks!! I have a couple that are more beat up. We should do a show us your well used Malkoffs thread.
Sadly, all my Malkoffs still look perfect. Clearly I'm doing it wrong...
--flatline
Does the M361N have the same PWM for the low modes that the MDC head has?
I've been assuming it has the same PWM as my MDC AA head which is why I've ignored it.
BTW, i love seeing these lights with some wear on them. A pristine malkoff just looks wrong somehow...
--flatline
--flatline
Mine too. One of my tricaps picked up a ding while rolling around in my flashlight drawer.
I'm still grieving.
PWM is not a bug, it's a feature. Look at a fan in the car and you see something amazing. I tried the shower trick but didn't really see anything.
The frequency is way too high to detect it with the eye.
Malkoff M361 uses a flicker rate of 310 Hz. The human eye cannot see anything above about 100 Hz, maybe 150 Hz at most. Cheaper lights like Fenix L0D are about 120 Hz if I recall correctly, or something close to that. Though in all honesty I cannot see 150Hz either.
Anyway, 310 Hz is above the threshold where most people can see it. If nobody tells you M361 has PWM, you will never know. You do not see it in normal usage. Unless you work 100% in running showers. And even then it's Uber cool. when I saw that, I was amazed.
If you put this in their heads that they can see PWM, they will see 1200 Hz also, or think that they do, which is not physically possible, unless in very specific conditions, not walking through the woods at night.
The statement I can see PWM is meaningless because it does not qualify what frequency they can see.
I believe the m61 T6 xml-2 5000k had the voltage range of a regular m61. The unique thing is that there are not many XM-L leds in the Malkoff drop-in line up with this voltage range.
