jch79
**Do Not Feed The Vegan**,
*Background in homage to WP's old photos - where are you Donald?!?
TranquillityBase has succeeded in making a light like no other that I know of. Utilizing RV7's new driver board, which is driving a Seoul USV0I (mmmmm... SV0 tint...) being directed by a McR-20, this versatile and robust light is machined with the precision that we all know comes out of this fellow Wisconsinite. Here's Scott's initial description and discussion about the light, which shows more photos of the custom-made heatsink and the driver.
The light is bead blasted titanium, with Scott's well-known checkerboard grip pattern:
It's also got a partially knurled head and tail (McGizmo housing design, utilizing a McClicky switch), which makes this thing pretty darn hard to slip outta your hand!
The size of the 1AA tube and the dual-layer driver board make the light about 4 5/8" long - longer than your average 1x123 light, but shorter than your average 2x123 light. Here's a comparison photo with a couple other TB lights:
Left: TB 18650, A19 head (by Morelite)
Middle: TB Ti AA
Right: TB 1x123, A1 head
Notice the smooth bezel ring on the TB AA - very clean and cool looking. :twothumbs
The 4-level driver of this light is pretty incredible. The light operates as such: Momentary taps (or quickly clicking on-off-on) on the switch cycles through the levels 1-4. When you get to the level you want, stay there for momentary, or depress to keep it there. The next time you turn the light on, it will be in the mode you left it in. Pretty simple IMHO!
Runtime tests on levels 3 & 4, each with an Eneloop 2000mAh and a Sanyo 2700mAh:
Runtime tests on level 1 & 2, with a Sanyo 2700mAh:
And then a "big picture" runtime chart, of levels 1-4 with the Sanyo 2700:
Not bad, eh?? :naughty: I had no idea it'd hold that bright for that long, off of one AA battery. :rock:
Thanks to Scott for building this thing, from the ground up, and RV7, for making available such a great board! It makes me wonder why so many of my lights are 123-based, when this AA light can kick some serious butt! :thumbsup:
🙂 john
