(CLOSED) $urefire C head 1x26500 1x26650 & 2x26500
[size=+4]
[size=+3]
Hi folks, Here I have some more new toys for you.
These bodies are similar to these but with some changes and improvements.
Bodies have slightly larger ID to accomodate 27mm cell.
A body that takes IMR 26500 cell, $urefire C head and comes with tail cap and O'rings.
All bodies and tail caps are black hard anodized and no other color available.
Picture shows 2x26500 body with installed tail cap on left and 1x26500 body on right.
1x26650 will be similar to 1x26500 but 17mm longer.
Tail cap has more attractive milling similar to M6
Tail cap can accept either version B of these or McClicky. An adapter included to use McClicky switch.
Tail cap accepts key ring.
Switch boot is easier to operate with choice of black, orange or green GID
Will take many of D26 lamp assemblies such as FM-D26, G4 D26, LF D26, original P90, Malkoff drop in and ....
I strongly suggest these for single 26500 or 26650
[size=+1]$urefire Deep Turbo Heads are available here.[/size]
Possibilities are endless:
Use Strion bulb with 1x26500 for over an hour run time or 1x26650 for over two hours run time and 140 lumens.
Use P7 or STT-90 drop in with 1x26500 or 1x26650 and see the light.
Use Malkoff drop in with 1x26500 / 1x26650 for long run.
2x26500 with WA1274 with 50 minutes run time.
2x26500 with 6.6 volt Axial bulb with 40 minutes run time.
2x26500 with TL-3 bulb with 2 hours run time.
3x26500 with 1909 bulb for 20 minutes. (use AW's soft start switch)
Advantages:
Not only you will get long run time compare to 17mm or 18mm cells but brighter output because of less voltage sag, less stress to cells and less frequent recharge.
2C is slightly longer than 9P but shorter than 2x18650 while has much more current capability.
1x26500 is shorter than 1x18650
Body outside diameter at knurling is about 32mm which is about 6mm fatter than original 9P but tail cap has 35mm diameter
Each body comes with one throat o'ring, two tail side O'rings, one tail cap, one switch adapter and one dust cover boot. No bezel, No lamp assembly, No switch and No batteries included.
Simply insert and tighten your McClickie inside the provided ring then install this switch assemly inside tail cap. Please see picture.
Price:
Black 1x26500 $58 (NOT AVAILABLE)
Black 1x26650 $63 (NOT AVAILABLE)
Black 2x26500 $65 (NOT AVAILABLE)
Black 2x26650 $73 (NOT AVAILABLE)
Black 3x26500 $75 (NOT AVAILABLE)
1x26650 to 1x18650 Heat Sinked Black Aluminum Sleeve $18 (NOT AVAILABLE)
Beefy head $32 with purchase of above body only.
McClickie switch $10 (NOT AVAILABLE) with purchase of body or tail cap. Do not use with 1909 bulb
Extra boot (switch cover) $1 (NOT AVAILABLE) with purchase of body. (Black, orange or GID)
Shipping to States $6 (any quantity)
Internationaly $8 (any quantity)
Please add 4% to total for CC paypal fee.
No reservation please. You must pay [size=+2]FIRST[/size] then claim your spot by posting here. I will sign your name right after receiving payment unless you paying by MO.
Please don't pay if you may change your mind. There will not be any refund.
It is [size=+1]ABSOLUTELY NECESSARY[/size] to pick [size=+1] next [/size] available and valid number, post detail of your order here and paypal note along with your CPF handle.
It is [size=+1]ABSOLUTELY NECESSARY[/size] to pick [size=+1]next[/size] available and valid number, post detail of your order here and paypal note along with your CPF handle.
I will never figure out what for is your payment and from whom without above information therefore I will reject payment.
Example:
Mr Gunfire for #68 1x26500 with black boot
Paypal: [email protected]
Please PM for postal money order payment.
Please see:
Cooly 1x26650 here
D36 bodies here.
18350, 18500 & 18650 E bodies here.
MN sockets here.
A2 sockets here.
D26 socket/reflectors here.
2x26500 and 3x26500 Exotic M*gs here.
SS 18650 E body here
E1, E2, E3 & E4 Body here
E to C adapter here
Mini Turbo Head here
Deep Turbo Head here
D36 bodies here.
C bodies here.
MN sockets here.
[size=+2]Your CPF handle in paypal note is critical and very very necessary.[/size]
[size=-2]#01 1x26500 $58 Not So Bright paid shipped
#02 1x26500 $58 william lafferty paid shipped
#03 1x26500 $58 lctorana paid shipped
#04 1x26500 $58 AW paid shipped
#05 1x26500 $58 AW paid shipped
#06 1x26500 $58 nailbender paid shipped
#07 1x26500 $58 tx101 paid shipped
#08 1x26500 $58 bigchelis paid shipped
#09 1x26500 $58 ElectronGuru paid shipped
#10 1x26500 $58 AW paid shipped
#11 1x26500 $58 AW paid shipped
#12 1x26500 $58 Justin Case paid shipped
#14 1x26500 $58 Chodes paid shipped
#15 1x26500 $58 BelliR6 paid shipped
#16 1x26500 $58 daimleramg paid shipped
#17 1x26500 $58 jefft paid shipped
#18 1x26500 $58 Justin Case paid shipped 0308073000016712XXXX
#19 1x26500 $58 Justin Case paid shipped 0308073000016712XXXX
#20 1x26500 $58 supasizefries paid shipped 0309033000002374XXXX
#21 1x26500 $58 QtrHorse paid shipped 0309033000002374XXXX
#22 1x26500 $58 my_gentle_cry paid shipped CP184178609US
#23 1x26500 $58 Visible EM Wave paid shipped LC845348781US
#24 1x26500 $58 LightJunk paid shipped
#25 1x26500 $58 darkzero paid shipped 0309033000002376XXXX
#26 1x26500 $58 PoliceScannerMan paid shipped 0309033000002376XXXX
#27 1x26500 $58 jojobos paid shipped 0309033000002376XXXX
#28 1x26500 $58 PoliceScannerMan paid shipped 0309033000002376XXXX
#29 1x26500 $58 ElectronGuru paid shipped 2308044000002615XXXX
#30 1x26500 $58 ElectronGuru paid shipped 2308044000002615XXXX
#31 1x26500 $58 ElectronGuru paid shipped 2308044000002615XXXX
#32 1x26500 $58 ElectronGuru paid shipped 2308044000002615XXXX
#33 1x26500 $58 ElectronGuru paid shipped 2308044000002615XXXX
#34 1x26500 $58 mfrey paid shipped 0309033000002378XXXX
#35 1x26500 $58 Drewfus2101 paid shipped 0309033000002377XXXX
#36 1x26500 $58 mknewman paid shipped 0309033000002378XXXX
#37 1x26500 $58 mknewman paid shipped 0309033000002378XXXX
#38 1x26500 $58 fitzDaug MO received shipped 0309114000004626XXXX
#39 1x26500 $58 darkzero paid shipped 0309114000004626XXXX
#40 1x26500 $58 nailbender paid shipped 0309114000004626XXXX
#41 1x26500 $58 nailbender paid shipped 0309114000004626XXXX
#42 1x26500 $58 greenpea76 paid shipped 0309114000004626XXXX
#43 1x26500 $58 QtrHorse paid shipped 0309114000004626XXXX
#44 1x26500 $58 QtrHorse paid shipped 0309114000004626XXXX
#45 1x26500 $58 darkzero paid shipped 0309114000004626XXXX
#46 1x26500 $58 ElectronGuru paid shipped 2308044000003099XXXX
#47 1x26500 $58 ElectronGuru paid shipped 2308044000003099XXXX
#48 1x26500 $58 ElectronGuru paid shipped 2308044000003099XXXX
#49 1x26500 $58 ElectronGuru paid shipped 2308044000003099XXXX
#50 1x26500 $58 ideefixe paid shipped 0309114000004635XXXX
#51 1x26500 $58 farrsp2270 paid shipped 0309114000004635XXXX
#52 1x26500 $58 E-J-J paid shipped LC845286486US
#53 1x26500 $58 chuck614 paid shipped 0309114000004635XXXX
#54 1x26500 $58 yellow paid shipped LC845286565US
#55 1x26500 $58 Grigoriy paid shipped LC845286543US
#56 1x26500 $58 Ferry paid shipped LC845286557US
#57 1x26500 $58 Joe_torch MO received shipped LC845286804US
#58 1x26500 $58 ptolemy paid shipped 2308218000002879XXXX
#59 1x26500 $58 RocketTomato paid shipped 0308073000016682XXXX
#60 1x26500 $58 Nite paid shipped 0309288000011043XXXX
#61 1x26500 $58 QtrHorse paid shipped 0309288000011044XXXX
#62 1x26500 $58 SHIN paid shipped LC138289942US
#63 1x26500 $58 Simon520 paid shipped 0309322000007795XXXX
#64 1x26500 $58 Simon520 paid shipped 0309322000007795XXXX
#65 1x26500 $58 mknewman paid shipped 2308294000000181XXXX
#66 1x26500 $58 mknewman paid shipped 2308294000000181XXXX
#67 1x26500 $58 mknewman paid shipped 2308294000000181XXXX
#68 1x26500 $58 mknewman paid shipped 2308294000000181XXXX
#69 1x26500 $58 mknewman paid shipped 2308294000000181XXXX
#70 1x26500 $58 Ferry paid shipped LC138288023US
#71 1x26500 $58 bennytheblade paid shipped 2308218000002887XXXX
#72 1x26500 $58 Phyltre paid shipped 03092880000110432012
#73 1x26500 $58 Bob96 paid shipped 03080730000166847054
#74 1x26500 $58 Bob96 paid shipped 03080730000166857275
#75 1x26500 $58 scalez paid shipped 23082180000028860916
#76 1x26500 $58 357mag1 paid shipped 03092880000117151510
#77 1x26500 $58 357mag1 paid shipped 03092880000117151510
#78 1x26500 $58 357mag1 paid shipped 03092880000117151510
#79 1x26500 $58 Roc paid shipped LC547780020US
#80 1x26500 $58 Roc paid shipped LC547780020US
#81 1x26500 $58 Davey paid shipped LC547780617US
#82 1x26500 $58 Hammer Train paid shipped LC547817691US
#83 1x26500 $58 rookie paid shipped 03101230000057495187
#84 1x26500 $58 hondaexp paid shipped 03101230000057505992
#85 1x26500 $58 ronkun38 paid shipped LC547811022US
#86 1x26500 $58 kellyglanzer paid shipped LC547811036US
#01 1x26500 (BLEMISHED) $55 Mike Docherty paid shipped 03103490000027889927
#01 1x26650 $63 mknewman paid shipped 0309114000004635XXXX
#02 1x26650 $63 mknewman paid shipped 0309114000004635XXXX
#03 1x26650 $63 nailbender paid shipped 0309114000004635XXXX
#04 1x26650 $63 nailbender paid shipped 0309114000004635XXXX
#05 1x26650 $63 nailbender paid shipped 0309114000004635XXXX
#06 1x26650 $63 daimleramg paid shipped LC845286588US
#07 1x26650 $63 Joe_torch MO received shipped LC845286530US
#08 1x26650 $63 ElectronGuru paid shipped 0309114000004635XXXX
#09 1x26650 $63 ElectronGuru paid shipped 0309114000004635XXXX
#10 1x26650 $63 arek98 paid shipped 0309114000004635XXXX
#11 1x26650 $63 arek98 paid shipped 0309114000004635XXXX
#12 1x26650 $63 yellow paid shipped LC845286565US
#14 1x26650 $63 OneBigDay MO received shipped 0308073000016682XXXX
#15 1x26650 $63 ptolemy paid shipped 2308218000002879XXXX
#16 1x26650 $63 JohnF paid shipped 0308073000016682XXXX
#17 1x26650 $63 Crater_Crater Echeck cleared shipped 0308073000016683XXXX
#18 1x26650 $63 ElCattivo paid shipped LC845286716US
#19 1x26650 $63 OneBigDay paid shipped 0308073000016683XXXX
#20 1x26650 $63 flashfiend paid shipped 0308073000016683XXXX
#21 1x26650 $63 QtrHorse paid shipped 0309288000011044XXXX
#22 1x26650 $63 BigHonu paid shipped 0309288000011044XXXX
#23 1x26650 $63 tstartrekdude paid shipped 0309288000011043XXXX
#24 1x26650 $63 supergravy paid shipped 0309288000011044XXXX
#25 1x26650 $63 donn_ paid shipped 2308218000002879XXXX
#26 1x26650 $63 TSWrench paid shipped 0309288000011111XXXX
#27 1x26650 $63 mknewman paid shipped 2308294000000181XXXX
#28 1x26650 $63 mknewman paid shipped 2308294000000181XXXX
#30 1x26650 $63 (Shipping early June 2010) edelbrock paid shipped 03092880000117167252
#31 1x26650 $63 upsidedownviking paid shipped 03092880000117167238
#32 1x26650 $63 rookie paid shipped 03092880000117167245
#33 1x26650 $63 rookie paid shipped 03092880000117167245
#34 1x26650 $63 Noctis paid shipped 03092880000117169331
#35 1x26650 $63 ming560 paid shipped LC547780047US
#36 1x26650 $63 jdriller paid shipped 03092880000117168310
#37 1x26650 $63 357mag1 paid shipped 23082180000028796680
#38 1x26650 $63 Davey paid shipped LC547780055US
#39 1x26650 $63 mknewman paid shipped 03093220000077959110
#40 1x26650 $63 357mag1 paid shipped 23082180000028796680
#41 1x26650 $63 Roc paid shipped LC547780020US
#42 1x26650 $63 dtb1 paid shipped 03092880000117168327
#43 1x26650 $63 kayakjax paid shipped 03092880000117168365
#44 1x26650 $63 LightJunk paid shipped 03092880000117167269
#45 1x26650 $63 Chodes paid shipped LC547780064US
#46 1x26650 $63 Tedfs paid shipped 03092880000111129393
#47 1x26650 $63 Tedfs paid shipped 03092880000111129393
#48 1x26650 $63 VanIsleDSM paid shipped LC547780135US
#49 1x26650 $63 euroken paid shipped 03093220000077959127
#50 1x26650 $63 swrdply400mrelay paid shipped 03092880000111142699
#51 1x26650 $63 nailbender paid shipped 03092880000111142682
#52 1x26650 $63 purelite paid shipped 03092880000111148547
#53 1x26650 $63 M59/80 paid shipped LC547780325US
#54 1x26650 $63 kellyglanzer paid shipped LC547817878US
#55 1x26650 $63 RedfishBluefish paid shipped 03092880000110424710
#56 1x26650 $63 morelightnow pending cleared shipped 03092880000110389866
#57 1x26650 $63 1301 paid shipped LC547811138US
#58 1x26650 $63 rookie paid shipped 03101230000057495187
#59 1x26650 $63 rookie paid shipped 03101230000057495187
#60 1x26650 $63 Drywolf paid shipped 03101230000057971018
#61 1x26650 $63 Drywolf paid shipped 03101230000057971018
#62 1x26650 $63 rookie paid shipped 03092880000110388104
#63 1x26650 $63 rookie paid shipped 03092880000110388104
#64 1x26650 $63 QtrHorse paid shipped 03101230000057971001
#65 1x26650 $63 QtrHorse paid shipped 03101230000057971001
#66 1x26650 $63 Sunlight MO received shipped]
#67 1x26650 $63 aeroflash paid shipped 03101230000057505350
#68 1x26650 $63 openbolt1 MO received shipped 03101230000057518305
#69 1x26650 $63 openbolt1 MO received shipped 03101230000057518305
#70 1x26650 $63 rookie paid shipped 03112550000058007225
#71 1x26650 $63 rookie paid shipped 03112550000058007225
#01 1x26650 (BLEMISHED) $58 EvilPaul2112 paid shipped 03101230000057518329
#01 2x26500 $65 Jay T paid shipped
#02 2x26500 $65 lctorana paid shipped
#03 2x26500 $65 nailbender paid shipped
#04 2x26500 $65 bigchelis paid shipped
#05 2x26500 $65 AW paid shipped
#06 2x26500 $65 AW paid shipped
#07 2x26500 $65 Justin Case paid shipped
#08 2x26500 $65 QtrHorse paid shipped
#09 2x26500 $65 cenz paid shipped
#10 2x26500 $65 cenz paid shipped
#11 2x26500 $65 Chongker paid shipped
#12 2x26500 $65 Hawkeye5 paid shipped
#14 2x26500 $65 BelliR6 paid shipped
#15 2x26500 $65 Visible EM Wave paid shipped LC845348781US
#16 2x26500 $65 tankahn paid shipped LC845348818US
#17 2x26500 $65 LightJunk paid shipped
#18 2x26500 $65 LightJunk paid shipped LC845285843US
#19 2x26500 $65 ShineOnYouCrazyDiamond paid shipped 0309033000002378XXXX
#20 2x26500 $65 fitzDaug MO received shipped 0309114000004626XXXX
#21 2x26500 $65 ElectronGuru paid shipped 2308044000003099XXXX
#22 2x26500 $65 ElectronGuru paid shipped 2308044000003099XXXX
#23 2x26500 $65 ElectronGuru paid shipped 2308044000003099XXXX
#44 2x26500 $65 ElectronGuru paid shipped 2308044000003099XXXX
#25 2x26500 $65 ElectronGuru paid shipped 2308044000003099XXXX
#26 2x26500 $65 my_gentle_cry paid shipped LC845286035US
#27 2x26500 $65 my_gentle_cry paid shipped LC845286035US
#28 2x26500 $65 Not So Bright paid shipped 0309114000004627XXXX
#29 2x26500 $65 Iliger paid shipped LC845286146US
#30 2x26500 $65 Freaker paid shipped 0309114000004627XXXX
#31 2x26500 $65 donn_ paid shipped 0309114000004628XXXX
#32 2x26500 $65 Nite paid shipped 0309288000011043XXXX
#33 2x26500 $65 sbelyo paid shipped 0309288000011043XXXX
#34 2x26500 $65 brunt_sp paid shipped LC138289899US
#35 2x26500 $65 Joe_torch MO received shipped LC138287941US
#36 2x26500 $65 daimleramg paid shipped LC138289871US
#37 2x26500 $65 donn_ paid shipped 23082180000028796444
#38 2x26500 $65 mknewman paid shipped 2308294000000181XXXX
#39 2x26500 $65 mknewman paid shipped 2308294000000181XXXX
#40 2x26500 $65 mknewman paid shipped 2308294000000181XXXX
#41 2x26500 $65 mknewman paid shipped 2308294000000181XXXX
#42 2x26500 $65 mknewman paid shipped 2308294000000181XXXX
#43 2x26500 $65 LuxLuthor paid shipped 0309288000011110XXXX
#44 2x26500 $65 jdriller paid shipped 0309288000011043XXXX
#45 2x26500 $65 LightJunk paid shipped 0308073000016684XXXX
#46 2x26500 $65 scalez paid shipped 23082180000028860916
#47 2x26500 $65 morepho87 paid shipped 03092880000111109203
#01 2x26650 $73 edelbrock paid shipped 03092880000117167252
#02 2x26650 $73 ming560 paid shipped LC547780047US
#03 2x26650 $73 mknewman paid shipped 03093220000077959110
#04 2x26650 $73 357mag1 paid shipped 23082180000028796680
#05 2x26650 $73 TSWrench paid shipped 03092880000111149513
#06 2x26650 $73 BigusLightus paid shipped 03092880000109968270
#07 2x26650 $73 Simon520 paid shipped 03092880000110377153
#08 2x26650 $73 RedfishBluefish paid shipped 03092880000110424710
#09 2x26650 $73 Sunlight MO received shipped 03101230000057505695
#10 2x26650 $73 m@tty paid shipped LC547811124US
#11 2x26650 $73 357mag1 paid shipped 03092880000110388111
#12 2x26650 $73 357mag1 paid shipped 03092880000110388111
#14 2x26650 $73 Drywolf paid shipped 03101230000057505343
#15 2x26650 $73 kellyglanzer paid shipped LC547810415US
#16 2x26650 $73 warmurf paid shipped LC547840134US
#17 2x26650 $73 91FromStars paid shipped 03103490000026453396
#18 2x26650 $73 solidtrax paid shipped 03103490000027891937
#19 2x26650 $73 dkman paid shipped LC548063745US
#20 2x26650 $73 cenz paid shipped LC452889605US
#21 2x26650 $73 Rommul paid shipped 03112550000058020996
#01 3x26500 $75 Nite paid shipped 0309288000011043XXXX
#02 3x26500 $75 mknewman paid shipped 0307333000015983XXXX
#03 3x26500 $75 mknewman paid shipped 0307333000015983XXXX
#04 3x26500 $75 Simon520 paid shipped 0309288000011044XXXX
#05 3x26500 $75 mknewman paid shipped 2308294000000181XXXX
#06 3x26500 $75 mknewman paid shipped 2308294000000181XXXX
#07 3x26500 $75 mknewman paid shipped 2308294000000181XXXX
#08 3x26500 $75 mknewman paid shipped 2308294000000181XXXX
#09 3x26500 $75 mknewman paid shipped 2308294000000181XXXX
#10 3x26500 $75 Ferry paid shipped LC138288023US
#11 3x26500 $75 Not So Bright paid shipped 0309288000011111XXXX
#12 3x26500 $75 LuxLuthor paid shipped 0309288000011110XXXX
#14 3x26500 $75 Freaker paid shipped 2308218000002887XXXX
#15 3x26500 $75 LightJunk paid shipped 0308073000016684XXXX
#16 3x26500 $75 Iliger paid shipped LC547920107US
#17 3x26500 $75 BelliR6 paid shipped 0308073000016684XXXX
#18 3x26500 $75 Roc paid shipped LC547780020US
#19 3x26500 $75 Roc paid shipped LC547780020US
#20 3x26500 $75 sprinkle paid shipped 03092880000117168358
#21 3x26500 $75 Chodes paid shipped LC547811040US
#22 3x26500 $75 (SOLD)
#23 3x26500 $75 RCANTOR paid shipped 03103490000027784932
#24 3x26500 $75 jwyj paid shipped 23082180000028858784
#25 3x26500 $75 Mike Docherty paid shipped 03103490000026448590
#26 3x26500 $75 BelliR6 paid shipped 03103490000027883468
#27 3x26500 $75 taylor paid shipped LC547987024US
#28 3x26500 $75 mamelo paid shipped LC452768179US
#01 Tail cap with boot and switch housing ring (No switch of any kind included) $28 OtisCampbell paid shipped 03103490000027791015
#02 Tail cap with boot and switch housing ring (No switch of any kind included) $28 rookie paid shipped 23071770000008609277
#03 Tail cap with boot and switch housing ring (No switch of any kind included) $28 rookie paid shipped 23071770000008609277
#04 Tail cap with boot and switch housing ring (No switch of any kind included) $28 Van_RC paid shipped LC547840125US
#05 Tail cap with boot and switch housing ring (No switch of any kind included) $28 Jimed315 paid shipped 23071770000008609345
#06 Tail cap with boot and switch housing ring (No switch of any kind included) $28 brandocommando paid shipped 03103490000027790964
#07 Tail cap with boot and switch housing ring (No switch of any kind included) $28 LichtAn! paid shipped LC547840117US
#08 Tail cap with boot and switch housing ring (No switch of any kind included) $25 (BLEMISHED) nc_hooper paid shipped 03103490000027819511
#09 Tail cap with boot and switch housing ring (No switch of any kind included) $25 (BLEMISHED) nc_hooper paid shipped 03103490000027819511
#10 Tail cap with boot and switch housing ring (No switch of any kind included) $25 (BLEMISHED) pmorris paid shipped 03110240000234055387
#01 Black 1x26650 Extension Tube $30 cenz paid shipped LC452889605US
#02 Black 1x26650 Extension Tube $30 rookie paid shipped 03112550000058007225
#03 Black 1x26650 Extension Tube $30 rookie paid shipped 03112550000058007225[/size]
www.usps.com
No more sale to this guy:
http://www.cpfmarketplace.com/mp/showthread.php?t=237832
[size=+1]Please find link of my other products[/size] [size=+2]here[/size][size=+1] and click on each link you are interested on.[/size]
[size=+4]
(C L O S E D)
[/size]
[size=+3]
Please read completely before you post or buy then pay and post.
Absolutely NO reservation.
[/size]Absolutely NO reservation.
Advantages:
Price:
Example:
Please see:
Cooly 1x26650 here
D36 bodies here.
MN sockets here.
A2 sockets here.
E to C adapter here
D36 bodies here.
C bodies here.
MN sockets here.
www.usps.com
[size=+3](C L O S E D)
[/size]
