Whining in Connexion?
Mdinana
Yesterday I started to hear a high pitched whine coming from my Lumapower Connexion. It started after a few minutes on high. Today, it returned, but was on med and low as well. I loosened the head, but it didn't go away.I'm running Energizer L91.Any thoughts on what it is, and recommended actions?
It's inductor whine; a component in your light's circuitry has something loose way down at the microscopic level, which vibrates as energy passes through/near it.
There's no way to fix it by hand; it may go away if you use a different battery type, but the only sure way to repair it is to return it to the seller for an exchange.
I have had this problem with a lot of my lights from day one.
MEH!
Is this the Connexion X2 or the original model?
My ConneXion (original) has always made a noise (highest pitched on highest brightness, and also louder on lower brightness). I'm using alkaline cells BTW (don't have any other cells or I would try them as a test).
I don't hear the same on my newer ConneXion X2, though I perceive something is coming from it. I think it is just too high pitched for my older ears to hear.
