It was 4000k now says 5000k???
Dude, please stop. Your misguided criticism and counterproductive "suggestions" don't contribute to meaningful discussion and aren't really helping anything except making you look like a frustrated person.
1. It was never 4000K. Like Bob_McBob said, all "d" ("daylight") models are 5000K.
2. ZL evidently don't care about producing "killer throwers". They've only made, like, two or three smooth-reflector models in the last 7 years or so I've been following them. They care about producing general-purpose, bright, power-efficient lights. Oslon Black Flat (which is what, 5W max?), unsurprisingly, is a poor fit for any of those—it's only useful for pencil-beam lights which are an extreme niche even among flashlight enthusiasts. I suppose you're free to mod an SC700d, but I'm not sure it sounds quite as enticing as you make it. I'm not even sure it would throw very well with such a shallow reflector.
3. The LED used in this light, 90+ CRI 5000K XHP70.2, has its maximum power draw rated at 29W—you can check it on Cree's site. Under any normal conditions (e.g. not being water-cooled or anything) it can only sustain 3000 lm for several seconds at that power before heating up and being throttled down by the PID controller to begin with. ZL tend to push their LEDs to the limit of the spec, but I don't remember them significantly exceeding it even once. But even if they did, it would still be throttled down to below 3000 instantly—so it would actually spend even less time at a high brightness as it would heat up quicker. It would also hurt battery compatibility and drastically reduce the window of battery charge state at which you can still turn the light on H1 as the side-effect owing to insane voltage sag. Why would they want that? Why would
you?
Basically, what all of this suggests is that you want a completely different light from a completely different company, so you might want to visit a completely different thread instead.
