I was scrounging around here a few months ago, trying to find an LED for work, and bought a Fenix TK11, and love it. I bought a few Ultrafire 18650 rechargeable batteries, and that works just fine.
I tried finding a thread with general incandescent reviews, but couldn't find one.
I want a smaller SUREFIRE inca light, either 1 18650, 2 AA's or 2 AAA's that is bright as hell. It will be my backup in case I get stuck in a foggy situation, and the LED will just reflect back at me. I've been kicking myself for only carrying 1 light. I looked on the surefire site, but there were not any that caught my eye.
I want to go with surefire because, I can get a huge discount on them, and I know they will last a long time.
Thanks.
E2/E2e/E2D with lumens Factory lamp assemblies and/or two types of rechargeable batteries or primaries. There are several bulb options as well. Let me break it down for you.
E2e + 2xCR123 + MN02 = Moderate brightness combined with very long runtime on primary CR123 lithium cells. This is the least bright alternative lamp assembly for the 2xCR123 E series. Excellent setup for camping, power outages, emergency, indoors and every other task when you don't need "tactical" brightness or long range illumination.
E2e + AW 17670 + HO-E1R = very long runtime, excellent color temperature with a very flat output discharge. Decent brightness for general purpose tasks. The best "free lumens" setup, hands down.
E2e + AW 17670 + EO-E1R = same as above, but with a bit less runtime and more brightness overall. Throw and brightness on this setup is greater than a stock SureFire P60 lamp assembly on primaries. This is a fantastic setup!
E2e + 2xCR123 + HO-E2A = same as the stock SureFire MN03, but it has better throw and less oval beam shape. Cheaper alternative than MN03 if you want to run primary batteries.
E2e + 2x AW RCR123 + HO-E2R = same as above setup, uses rechargeable CR123 instead of primaries (also known as 16340 cells or RCR123 3.7v)
E2e + 2x AW RCR123 + EO-E2R = the most powerful alternative for common li-ion RCR123 batteries. Significantly brighter than any other setup mentioned here. It has increased throw, spill and everything else. Runtime is shorter, though.
E2e + 2x IMR 16340 + IMR-E2 = insane power in a tiny form factor. The power of a
SureFire M3 coming from a little E2/E2e/E2D host. It
must be used ONLY with 16340 IMR batteries from AW,
no exceptions.
There you have it. 7 complete different setups, without the need for hunting after adapters, extensors, modifications, boring out services, aftermarket parts and what not. Just replace batteries and lamp assembly and you're good to go. I don't think there is any other incandescent flashlight as versatile as the SureFire E Series.
More info here:
http://www.lumensfactory.com/
You can get batteries, rechargers, lamp assemblies and accessories from
www.lighthound.com or directly from the user
AW in the CPF Market Place.
Cheers!
