What if radio waves could power a LED?
LukeA
near Pittsburgh
Another Nikola Tesla concept. It's interesting, but the same as it was in Tesla's time, hideously inefficient.
Illum
Central Florida, USA
radiowaves so far has been found to be able to
hmm...
its not a direct process.
Generally, it is accepted that everything vibrates under a specific frequency, it is said that if two objects oscillate at the same frequency, energy can be passed from point A to point B very easily...such was the case for inductive charging, but that was wire coils in close proximity...like a toothbrush
idleprocess
decamped
Interesting concept, but it's hard to imagine pulling a consistent 5mW from the ether at random, nevermind 20mW. Given the lack of details, I expect that those are peak rates in the lab (parked right next to a 240V 3-phase mains line near a leaky microwave), not average. If there was that much energy to be had from stray RF, I expect that cell phone cancer worries wouldn't be so baseless...
Illum
Well, we'd need to get shielded toilets, or get used to having the sensation of peeing on an electric fence everytime we have to go...
shielded toilets...:crackup:
If I didn't know better, I'd say there's a reason why outhouses were removed for you telecom operators, its way too dangerous to be outside at peak usages:nana:
we've already found that applying AC to a hotdog can power an LED...shall we progress down this route?
alpg88
nokia just announced, they build a cell phone that charges off radio waves.
when i was a kid i build small radio reciver that didn,t need battery, it was weak, required very low draw headphone to listen, volume was very low, but it worked,
Illum
ahh, long live those memories...the ones you can buy look like little rockets and you can adjust by pulling a small chunk of ferrite through a coil..
Many people doesn't know this, but LEDs can also be used to create voltage differentials in the presence of light, but its useless unless paired with some sort of amplifier and can be used to detect certain spectrum of light depending on the selection of the LED to create a linear relationship between voltage and light received. I think if it can be used in conjunction with this radiowave availability we might be able to see the elimination of roadlight power grids altogether :crackup:
Norm
Retired Administrator
Australia
A crystal set is what that small radio is called as a kid growing up in the 50's I built quite a few with the help of my dad and the volume wasn't necessarily low depending on your aerial, earth connections and headphones.
We also used to get a florescent tube going at almost full brightness but touching against the aerial on a mobile AM Ham radio transmitter, once the tube was started you could move away from the antenna with the tube glowing in your hand. I'm sure a LED with a tuned circuit and small antenna will glow in similar circumstances.
Fluorescent Tube Glow in High Potential Field
Coop
Tilburg, the Netherlands (perfectly reachable by U
A little off topic, but a story that stuck with me:
The story goes that the microwave oven concept was discovered by a radar technician. Who found that a bar of chocolate in his pocket had melted while he was working on live radar equipment. He didn't think much of it until he realized it was freezing at the time.
Actually, there was another reason for this. It was due to a groundbreaking new technology called 'Indoor plumbing'. :grin2:
Lumenshroom
Carthage, TN
Just a folk-tale. The frequency isn't sufficient to heat things, especially at that power and dilution. A microwave focuses 1600+watts of electricity worth of microwaves on food.
Mike Painter
In our lifetime? I'll venture yes. They are figuring it out for other devices, so it's just a matter of time.
http://tech.yahoo.com/blogs/null/143945
The inverse cube law applies.
1000 watts at 1 foot will be 10 watts at 2 feet.
About 2 watts at 3 feet and go down from there.
This ignores the input wattage and anything that would impede the signal along the way.
Within about 10 feet or so you would need an antenna, a battery, and sensitive equipment to amplify the signal.
LukeA
near Pittsburgh
Microwave waves aren't the same thing as radio waves. He said radio.
Don't attack the straw man with me. Coop related a story, which he admitted was off-topic, of Percy Spencer discovering the fact that microwave radiation could cook food. You said it was a folk tale. That's false; the story is true. I never said non-microwave radio waves could cook food.
Lumenshroom
Carthage, TN
Yeah, but he said it was radio waves that did it.
