Last night I bought a Streamlight Propolymer 4AA at a Turner's store here in S. Calif. It's a olive drab light with the new style clickie tail switch. I put the 4 AA Energizers in it that came with it and I was very impressed with the light it put out. I decided to go for a walk last night and had the light on for about 30 minutes. After 10 - 15 minutes the bezel of the light started getting warm but not too hot to touch. When I got home I removed the bezel and noticed the LED module had a hot electronics type smell coming from it and the area where the white plastic base meets the reflector felt tacky. Then I looked at the reflector and the reflective plating (specifically the area between the LEDSs and the center recessed portion)had started to distort. Looking into the module from what I can see there is no resistor under the board as some have reported. There is a resistor between each LED. The first three color bands on it are red, red and black. If I remember correctly that equals a 22 OHM resistor? Is this the most current version of this light or is it one of the earlier modules? I've never had to warranty anything with Streamlight. Do they make you mail the light into them or will the send replacement parts to you? If I have to ship it to them I may as well return the light to the store where I bought it since the shipping costs to Streamlight would really add to the cost of my new light. Is it unreasonable to expect this light to be able to run for 30 minutes to 1 hour at a time? If so then it won't work for my needs as a light to walk with. John
