woodrow
Hi, I have the origional Olight T20 M Q5 light, and while it is well built, its narrow spill and UI that makes me go through strobe and sos before going back to low has relegated it to glove box duty. When I saw the new 2010 version had lost the sos...and that when I heard that some of the Fenix R5 models had donut holes in their beams.... I decided to give the Olight T series a second look.
The new light is slightly shorter than the Q5 version...and bezel and tailcap walls are ever so much thinner...I do not think this will make the light less durable...as it is only slightly. All parts (besides the clip which is better now, and secured by a twist ring..so it will not fall off like the old one) are interchangable...and the light will still take an AW 17650 and will still work normally on all modes with one...unlike the Fenix PD30
The new bezel has a complete OP reflector..unlike the origional hybred. The hotspot and spill are Much wider than the Q5 (although the Q5's spill is small, it is very bright by consequince) The R5 model has a beam more like a Very Bright SF L4...which is great for lighting up everything in a room or path ahead..and I do like it much more than the Q5 version...there is also no donut hole.
Here are some indoor shots of each beam
The Q5
The R5
Low is nice and low and usable at 5 lumens. Med is a Huge jump to 170...which I find myself using most often. High is said to be 310, but It is a very small jump from med to the eye...I believe the light is putting out an honest 275-280l out the front...and ceiling bounce tests make it look easily brighter than the Q5...but I would not have minded a 100L med instead.
Here is an outdoor beamshot of each. Camera at 1" F/ 2.8 Iso 64
The Q5
The R5
Here is a beamshot of the Quark 123a x2 I took months ago. Same camera and settings
Overall I really like the New T20. I still am not a massive fan of its UI...but I find myself mainly in medium. The beam is so broad and smooth (and slightly warmer than the Q5) that it is great indoors, and while not a long distance spotter, It lights up everything out to 35-45 yards very well outdoors....and in New Mexico where desert walks often include centepedes and very large hairy spiders...I would rather have the broad spot and wide spill than a needle sharp beam.
I think the AA version of the light might be the best catch out there with more evenly spaced levels, over 200L on high...and the ability to take 2x14500's....how cool is that! But Im glad Batteryjunction got my funds for this one...It is turning into my go to edc light.
The Q5
The R5
The Q5
The R5
