Flashanator
that beast looks amazing, No really. AMAZING!!!!!!!!!!!!!!!!!!!
Well I have now ordered a 3000 watt Short arc power supply. It should be here in about 10 days. I have also orderd a 700 watt ballast for
hid bulbs. Because they come from the same place, I also threw in
1200 watt and 400 watt ballast. I will get both hot and cold igniters
with those also.
When all this crap gets here I will tell all were this stuff can be had.
Dave
Dave, as I understand it normal glass blocks 90% of the radiation that is below 300nm wavelenght. But 300-400nm is still UV. Does the HMI bulb have an outer glass shell, or is it naked like Maxabeam bulb? The arc chamber in these bulbs is quartz glass I think, that will not filter UV.
I noticed some minor eye symptoms couple hours after I had been walking around with the light when there was snow on the ground. So propably the snow was reflecting too much 'something' back at me. Could also be that the visible light intensity itself was little too much. Yeah looking into the beam would be a bad mistake. I have held my hand in the beam and it does not leave any marks, although the heat is pretty bad, but no sunburns or anything.
