katsyonak
- Joined
- May 9, 2007
- Messages
- 277
On 2 x SureFire SF123A the current draw is: 830mA
Just got my 6090 dropin and I can't get it to even flicker in my G2. I have tried with and without the outer spring and screwing in and out the heat sink. I turned the flashlight on and pushed the dropin down, moved it around, completely compressed, slightly compress, and everywhere in between and still not a flicker. With the original Surfire module, as soon as I drop it down it lights.
I took an electrical tester and tested continuity on the surefire module by putting one probe on the inner spring and one probe on the outer spring and it indicated a circuit. When I tried the 6090, it indicated no circuit. Does this test prove the 6090 is defective?
Thanks.
THats good to know. Any chance of measure it on 2 cr123s? 500-ishmah sounds like it would survive pretty well in a G2...
Why is the 6090 any better than thhe 1447. Both are constant current buck regulated drop-ins. You can add more voltage to the 6090, more than the 1447's 3.7-9 volts, but neither will regulate at 3 volts, more like 4.2+ volts. Is the 6090 running a Q5 as opposed to the 1447's Cree P4? My 1447 runs great and is cool, working fine in my G2Z with a metal bezel. Approximate lumens, using bounce with lightmeter, is around 100 lumens.
Bill
I checked two different DX6090s in the same SureFire 6P:
DX6090 #1, 810 ma for 2 SureFire CR123A cells, 560 ma, 2 AW cells
DX6090 #2, 780 ma for 2 SureFire CR123A cells, 520 ma for 2 AW cells
That is very nice; notice how the current drops with increasing voltage. It is using efficient constant current driver rather than LDO converter.
Does this run on single CR123A or single RCR123A? If so, can you find the battery current?
- Vikas
Bill
