spc
Got this spotlight at Northern tool.
It was yellow with black legs and a black bezel. It was advertised as 10mcp. Has 2x 6v SLA cells. Came with wall charger and car charger. This light has a nice metal reflector and a glass lens.
I had a 55w ballast and a couple bulbs. The bulbs were h1 and h3. The spotlight took an h4. I took the stock h4 halogen bulb apart and potted the h3 hid bulb into its base. So it fits like stock. (Before I potted it I focused it the best I could so the bulb would be plug and play).
First thing I did with the host was prep the heck out of it for a new paint job. Wash-scuff-wash-scuff-wash-paint. I used Krylon Fusion (good for plastic) ultra flat khaki on pretty much the whole thing.
The host has a 2-mode switch on the handle. For now I will use that so I re-wired it with heavier gauge wire to work with the ballast.
On the ballast I cut flat the power in plug that sticks out. I just used a dremel and cut it flush with the ballast housing. Then I soldered the power wires directly to the ballast. (doing this saved a little more than a 1/2 inch of space)
The ballast fit behind the reflector so all I did was make a little bracket and screwed it into the side of the host. The bracket holds the ballast with double sided tape
For some reason the glass and reflector wouldn't stay flush with the bezel so I mad a couple extra brackets to hold it tight (you can see the SS machine screws on the front)
It all went back together great and works very well. I still have some focusing to do. As it sits, it can light up trees over 300yds easy.
What do ya think? :tinfoil:
*changed the title to 55+w watts. After ballast modification 71w with approx 80% efficiency
