Barbolight U9 with SST-50 driven at 5A by H6CC
wquiles
Texas, USA, Earth
This is the second Barbolight U9 that I do for the same customer. The first one I finished about 10 months ago:Barbolight U9 with Warm White MC-E and HipCC
But for this one the owner wanted something more, something unique, and he suggested the SST-50. I suggested using the whole body (3x cells) for decent runtimes with the SST-50, but problem was the H6CC driver from George (www.taskled.com) was not yet available (Nov 2009), so this project was on hold for many months waiting on an efficient driver solution that could handle 3x LiIon cells. Once the driver was available, then another challenge was found: there is no way to fit the H6CC in the U9 host - too big for the body, and no room in the head. I suggested making a completely new, larger head from scratch, the owner agreed. But the head needed to have a couple of critical dimensions, so I decided to do the head design in a 3D package. So I bought Alibre Expert software and did the head design in the computer. Once I was happy with the design, I then started making the new head. I told the owner that I have a new Powder Coating system, and he said he would like his new light in Orange, so after many weeks of practicing/learning how to powder coat, I was able to get this light coated properly.
All in all I have been working on this second light for about 11 months, but it is now finished - I hope the owner will be happy with the result :D
Here is how the light looked like when I got it last year:
So I started disassembly:
Heating the factory epoxy to remove the head:
Barbolight uses a proven method for water-proofing the front lens, but it is one of high precision on the o-rings, lens OD, and o-ring groove. Since I have never done this before, I first practiced with a piece of scrap. First got the ID to be a sliding fit with the lens (I also have a spare lens to play with):
and then cut the o-ring grooves (I did two sets of them):
I tested the o-ring and lens (original head to the right side). It works really well:
I then played with an SST-50 mounted on a Mag D heatsink with various reflectors. In the end I selected a shallow reflector that worked well, which is the same one I used for the warm MC-E conversion earlier:
Size comparison of the original host, the original 3x NiMH pack, the will-always-be-missed "C" AW LiIon cells, and the newer but-larger-than-a-true-C-cell IMR:
With the tailcap fully inserted, and the spring fully rested, this is how things look like. I did several measurements on the cells, which allowed me keep the original tailcap spring since it meant that I could use either the longer Black/IMR cells since the spring will take up the difference :D
So the big day arrived when I got the new Al piece for the new head:
I cut it a tad longer than needed:
Here is the raw piece next to the original head:
Here is the piece next to the CAD drawing:
And I started work on the head:
Test ID with lens:
Cut o-ring grooves:
Work on the other side, to get ready to thread:
Test new metric threads:
Measure angle on original head - try to duplicate as much as possible:
and use original head to verify the setup is fairly accurate:
and finally make the cut (actually, many passes!):
Close enough in my book:
Round/smooth edges:
Not too bad:
The head here is still longer than it will be in the end, but here it is resting next to some of my original paper design/ideas and then the CAD drawing:
Since this build is modular and it will involve a couple of thermal transfer areas, I decided to use a copper core for the SST-50:
To maximize thermal transfer the piece was lightly sanded, corners smoothed out, etc.:
I then started to work on the heatsink/driver "module":
The copper core will be press fit with "thin" thermal paste and keep in place by a hidden set screw:
Again, for best thermal transfer, I decided to flow solder the SST-50 to the copper piece, so I made a small "post" so that I can then solder the wires from the sides:
I then worked on the other side of the module to make room for the H6CC current driver (set conservatively to 5Amps):
Reflow LED:
and test it to make sure I did not kill it:
Solder wires (very hard to solder wires "blind" from the underside!) and then test it at rated current (5A, but do to the long Power Supply wires the voltage was of course higher than the actual vf):
To provide mechanical strength to the solder wires, and so seal the cavity I used 2-part epoxy (even mixed glow in the dark powder for fun, although it is hard to see behind the reflector!):
To make 100% of the solid electrical contact for the negative battery, I am using a screw through the head, through the lip of the body - no chance for anything intermittent in a diving light!:
I then milled a relief area for the screw head:
I am also using a screw to keep the LED/driver module firmly in place:
Since it is a slight press fit, I drilled two small holes so that I could use thin nose pliers to align the module with the screw hole:
Since I have to trim the length of the head and since the head is too smooth and slippery, I cut some shallow grooves:
Here is now the finished head, next to the original one. The extra length is for the driver/module/wires/etc.. Is is also much stronger (although heavier) than the original head:
I then did a light boring to fit the "fatty" IRM C cells:
To prepare for powder coating, I bought some silicon plugs (these stand 500+ F, far lower than the 400F needed for the coating to take in the oven):
Unfortunately for the shinny finish, I had to sandblast the surface to aid in the adhesion of the powder coating:
I am using a copper wire through the center to ensure good electrical contact (critical for powder coating):
So after getting parts cleaned and pre-heated (to evaporate any residue):
I then coated them:
I then re-assembled the tailcap:
To give you an idea of scale/size:
With the IMR cells, this is how little the spring has to be compressed:
Here I am assembling the copper core to the heatsink module. The fit was so good, that even after applying this thin liquid, it became a press fit:
I then soldered and setup the H6CC to the other side of the module:
I then tested everything again:
I then applied a little epoxy to make sure things stay put:
This is the center conductor to the Bat +:
And this is how the module connects to the Bat - and Bat +:
I did a test fit and test for operation:
And then, with the head not fully screwed in, another test using real IMR cells:
I guess it is a coincidence that the all parts, including the cells are orange!:
I now have to make a custom fitted ring to hold the reflector in place:
I then sanded it for a light sliding fit in the head:
Once I was happy with the fit, I epoxied the centering ring to the reflector:
A coat of Krapton tape to make sure I can't have any shorts with the LED:
Here I am doing the final assembly (blue stuff is Loctite):
Seal the head to the battery tube (had to access sealant from side as top was dry!):
Lightly coat module with thermal paste:
and seat in place (here I am not done cleaning the interior - not that anyone will see this part anyway, but that is the way I am!):
and finally test the beam (unfortunately during bright daylight (see garage door open on left!):
I then took the reflector out, coated the edge with epoxy and glow in the dark powder:
In this photo you can see a "little" bit of the glow around the LED as well:
This o-ring on top of the reflector (once you install the lens) keeps the reflector in place and with zero rattles:
Here is the finished light:
Next to the warm MC-E version I did for the same owner back in January of this year:
I will post some beamshots tonight when it gets dark again :D
Will
Re: Barbolight U9 with SST-50 driven at 5A by H5CC
Control:
SST-50 at 5A:
Warm MC-E @ 2.8A:
Control:
SST-50 at 5A:
Warm MC-E @ 2.8A:
Control:
SST-50 at 5A:
Warm MC-E @ 2.8A:
Nice work Will, that really shows how in depth these builds are for people who don't know. And to think that probably doesn't even contain all the steps :eek:
That's an amazing job! I loved looking through this build. I'm sure the owner will be more than pleased with your bulletproof work.
Absolutely beautiful. :bow::bow::bow:
I always like to read your detailed step by step procedures. I can almost imagine I'm there while you're doing it.:)
Will, as always, totally *n*l retentive execution and attention to detail that I expect to see from you :)
Ever since I shipped you the h6cc I've been waiting to see what you were going to use it in, now I know. I'd hate to imagine how many hours went into this project!
cheers,
george.
Thanks for the informative build-report ! Very interesting, great work and nice light.
Edit: Fantastic beamshots ! You might be even better with camera then with lathe ;)
Nice / amazing work and build. :twothumbs
A couple of comments / questions:
- It looks like the new beam has simialar throw, but more flood, or is that just my eyes ? (edit - never mind, I see it is higher lux on the bricks)
- That is an interesting drill bit.
- Are you really able to build these in one attempt, or are you like me that it takes a few times ? :D
HarryN
HarryN
Thanks Harry :eek:
- Using the same reflector, so the beam and throw is "similar", but yes, the SST-50 has a significantly brigther output.
- That is an Allied Spade Drill that I got for this job, capable of drilling holes from 31/32" up to 1-3/8" (up to 4 3/4" deep), with a built-in MT3 arbor so it goes right on the tailstock of my lathe. And let me tell you, prior to this I have never used a more solid/stiff drill than this one. It went through the Al like it was not there, with zero deflection/chatter - I now "need" to buy more of them in other sizes :devil:
- If by one attempt you mean making only one of each piece, yes, I build these in one attempt. But it is a mental iterative process for me, so at least on paper it ALWAYS takes me several tries before I come up with something I feel will work and (more importantly) that it is within my tools and capabilities.
I treat these projects like a puzzle that I first solve in my head. I know in my head how I want the end product to look, so I picture in my head the various parts, and operations, and then I copy these ideas on a piece of paper. I then review what I wrote, and modify/adjust the idea until it sounds "right", based on what I think it is possible with the mill/lathe/hand tools/etc..
If something does not sound right, I walk away and think more about it. It might be hours or days before I go back and take another look. Most of the time, I have a new idea, and the design gets better, flows better. Since I write these down I can compare ideas and pick what works best for each step. Once a step is settled, I go on to the next challenge. I don't start metal cutting until I am about 90-95% confident that I have a good "solution", even though some small details are yet to be fully worked on - those get adjusted on the fly. And even then, as I am cutting/making parts/fitting parts, I adjust the idea/design slightly to make things work well.
It helps immensely to have good, accurate tools, and to have the DRO on the lathe - invaluable. It helps a lot that most all parts are fitted, so once I finish fitting one part, that part I don't have to touch/do again - I then fit other parts to it, and so on. Still, I was scared the whole time about the new head - that was a LOT of machining, and I had to get the threads done right, and the o-ring groves had to be fairly spot-on!. If I really mess up, I would have to start over from scratch - that is why I did the head on 3D CAD, to make sure I had enough metal in the right places. Still, just in case the brown stuff were to hit the fan, I did buy a larger piece of Al so I would not have to wait for a new piece to start over :crackup:
Will
