[ QUOTE ]
Orion said:
Wow. I guess I am just a little clueless on the whole physics of it.
[/ QUOTE ]
Hey, I'm just happy that you're interested enough to keep plugging away at it, and to not get discouraged or to tell the rest of the population that it isn't thinking right! /ubbthreads/images/graemlins/smile.gif
OK, I'll take another stab at this one...
[ QUOTE ]
Take, for instance, a cordless drill. While using the one battery, the other charges, so that when the first runs low, you switch out the battery with the fresh one and let the drained battery charge. I guess when it comes to doing this in a vehicle, charging the drained battery takes more energy.
[/ QUOTE ]
What you're saying *could* happen with an EV. The battery charges OFF the vehicle. To put it in your terms, pretend your drill has one battery in place to power the drill, and the other is rubber-banded onto the side of the thing. How is that second battery helping you? How are you charging it while you use the other battery? The only way it is getting charged is when it sits in the charger. Let's say the drill had regen brakes - it would still make more sense to put that power BACK into the pack that is snapped in instead of figure a way to get that power out to the second battery that is flapping in the breeze. I'll expand on this a bit more after the next comment...
[ QUOTE ]
How about this. Now please bare with me/entertain the notion/amuse me/be kind regardless of my ignorance /ubbthreads/images/graemlins/smile.gif. Rather than using regenerative braking to charge the second battery, you have a very small ICE [like from a scooter or something]. Something that gets like 100 mpg. Let IT charge the battery using a series of generators. Similar to the Hybrid [in a very small way], but all the power comes from the electric motor.
Yeah, I'm reaching. I just wish they'd increase the distance between charges. The distance currently would be fine for in town, but going on a long trip on vacation would be problematic, especially given our current energy setup.
[/ QUOTE ]
OK, let's try this way, and hope it makes some sense. You want a second battery to recapture whatever charge you may have. You see the first battery as offering 100 miles of range, and then once you've added a bit of charge to the second battery, you could drive some more miles by switching to it. We on the same page so far? Here comes the secret - why you don't need that second battery. While you drive along, draining your first 100 mile battery, you are leaving room in that battery to accept more charge. So after you've driven 50 miles, you have half your charge in that first battery. We still together? Now the secret: You've driven 50 miles without ever braking (so no charging has happened, even to the theoretical second battery) - but now you go down a huge hill, and use the regen. What happens now, is you put charge BACK into the primary battery. You fill it back up. Let's say you fill it up 25% from your braking adventure. Now, that very same primary pack will take you the 50% it had before braking, plus the extra 25% that you just added to it! Now your range has increased from 100 miles to a total of 125! Extra battery pack NOT NEEDED! Sure, you COULD have stuffed the regen into a second pack, but there is absolutely no reason to do so. You simply discharge and recharge the same pack as you drive. The ONLY time this does not work is if you want regen when the pack is 100% full. But just drive a few miles, and you've left enough room to capture quite a bit of braking, trust me! It has been considered to swap charged packs out at service stations like in your drill example. But you still only carry one pack at a time. You drive until you deplete your pack, and then swap for a charged one, just like the drill. But the ONLY way two packs in the car make sense is if you start with both of them charged - as if you had one pack twice the size. The ONE pack is all you need to recapture any regeneration that comes your way.
[ QUOTE ]
I'm with you all on this. I wish we would quit relying on foreign oil [heck, even domestic oil] and start using more environmentally friendly means to power things.
This is a great topic, by the way!! /ubbthreads/images/graemlins/smile.gif
[/ QUOTE ]
Here, here!
